81 KZ650 sprocket question
  • Phildo
  • Phildo's Avatar Topic Author
02 Sep 2009 14:55
#318636
I'm going to be replacing chain and sprockets on my 81 KZ650, is there any other sprockets that will work aside from OEM replacement?
  • bountyhunter
  • bountyhunter's Avatar
Re: 81 KZ650 sprocket question
02 Sep 2009 15:11
#318639
There are an assortment of different sprockets available if you want to change the gear ratio. Z1 sells them along with chains at very good prices.
  • Phildo
02 Sep 2009 16:34
#318655
Z1? Could you provide a link? Sorry, I'm new to bikes :)
  • timebomb33
  • timebomb33's Avatar
02 Sep 2009 16:44
#318660
z1 enterprises don't know how to do anything better than that those guy's sell everything you could every want for your kawi.
I THINK MY POWERBAND BROKE
  • Phildo
02 Sep 2009 16:51
#318663
Thanks man!
  • Phildo
02 Sep 2009 17:42
#318675
another question...what about changing to a belt drive instead of chain? is it possible?
  • JMKZHI
  • JMKZHI's Avatar
03 Sep 2009 04:34 - 03 Sep 2009 04:38
#318804
No, most likely. A shaft conversion might be possible.
As for the sprockets, a bigger front 630 sprocket on the CSR will be a tight fit. A 530 chain & sprockets might work better. Although I don't know much about this sort of thing, I wouldn't go smaller than a 30T rear, assuming you don't change the front 13T.
Last edit: 03 Sep 2009 04:38 by JMKZHI.
  • Phildo
03 Sep 2009 08:50
#318847
Okay, I wasn't too sure about the belt drive, thought I'd toss it out tho.
As for the chain, I'm gonna change out to a 530, just need to figure out what sprockets are needed
  • MFolks
  • MFolks's Avatar
03 Sep 2009 10:33
#318872
  • Phildo
03 Sep 2009 11:14 - 03 Sep 2009 11:18
#318880
Ok, maybe somebody can verify this info for me. OE front sprocket has 14 teeth while rear has 33 with an 84 link chain. Going by the 630 to 530 conversion guide on Z1, to retain stock ratios, I would swap to a 17 tooth front and 41 tooth rear (keeping the 13 tooth spline up front) with a 101 link chain.
Is this correct?
Last edit: 03 Sep 2009 11:18 by Phildo.
  • JMKZHI
  • JMKZHI's Avatar
03 Sep 2009 12:47
#318899
The 81 KZ650-H1 CSR came stock w a 13T Fr & 33T Rr sprockets and 630x84 chain.
  • bountyhunter
03 Sep 2009 12:57 - 03 Sep 2009 12:58
#318902
That's the equivalent ratio to stay close to what you have, which apparrently is one tooth up from stock on the front. Lots of people go up one on the front because these bikes are all geared too low stock.
Last edit: 03 Sep 2009 12:58 by bountyhunter.
