81 KZ650 sprocket question
- Phildo
02 Sep 2009 14:55
I'm going to be replacing chain and sprockets on my 81 KZ650, is there any other sprockets that will work aside from OEM replacement?
- bountyhunter
Re: 81 KZ650 sprocket question
02 Sep 2009 15:11
Phildo wrote:
There are an assortment of different sprockets available if you want to change the gear ratio. Z1 sells them along with chains at very good prices.I'm going to be replacing chain and sprockets on my 81 KZ650, is there any other sprockets that will work aside from OEM replacement?
- Phildo
02 Sep 2009 16:34
Z1? Could you provide a link? Sorry, I'm new to bikes
- timebomb33
02 Sep 2009 16:44
z1 enterprises don't know how to do anything better than that those guy's sell everything you could every want for your kawi.
I THINK MY POWERBAND BROKE
- Phildo
- Phildo
02 Sep 2009 17:42
another question...what about changing to a belt drive instead of chain? is it possible?
- JMKZHI
03 Sep 2009 04:34 - 03 Sep 2009 04:38
No, most likely. A shaft conversion might be possible.
As for the sprockets, a bigger front 630 sprocket on the CSR will be a tight fit. A 530 chain & sprockets might work better. Although I don't know much about this sort of thing, I wouldn't go smaller than a 30T rear, assuming you don't change the front 13T.
Last edit: 03 Sep 2009 04:38 by JMKZHI.
- Phildo
03 Sep 2009 08:50
Okay, I wasn't too sure about the belt drive, thought I'd toss it out tho.
As for the chain, I'm gonna change out to a 530, just need to figure out what sprockets are needed
- MFolks
03 Sep 2009 10:33
Some sprocket suppliers:
www.sprocketspecialists.com/
www.sunstar-mc.com/home.aspx
www.rebelgears.com/
www.schnitzracing.com
www.jtsprockets.com
www.pmfronline.com
A website for figuring ratio's
www.gearingcommander.com
www.rebelgears.com/
www.jtsprockets.com
www.pmfronline.com
- Phildo
03 Sep 2009 11:14 - 03 Sep 2009 11:18
Ok, maybe somebody can verify this info for me. OE front sprocket has 14 teeth while rear has 33 with an 84 link chain. Going by the 630 to 530 conversion guide on Z1, to retain stock ratios, I would swap to a 17 tooth front and 41 tooth rear (keeping the 13 tooth spline up front) with a 101 link chain.
Is this correct?
Is this correct?
Last edit: 03 Sep 2009 11:18 by Phildo.
- JMKZHI
03 Sep 2009 12:47
The 81 KZ650-H1 CSR came stock w a 13T Fr & 33T Rr sprockets and 630x84 chain.
- bountyhunter
03 Sep 2009 12:57 - 03 Sep 2009 12:58
Phildo wrote:
That's the equivalent ratio to stay close to what you have, which apparrently is one tooth up from stock on the front. Lots of people go up one on the front because these bikes are all geared too low stock.front sprocket has 14 teeth while rear has 33 with an 84 link chain. Going by the 630 to 530 conversion guide on Z1, to retain stock ratios, I would swap to a 17 tooth front and 41 tooth rear (keeping the 13 tooth spline up front) with a 101 link chain.
Last edit: 03 Sep 2009 12:58 by bountyhunter.
