RIM SIZE = TYRE SIZE
  • kano
  • kano's Avatar Topic Author
  • Not Another Bloody Limey!
01 Sep 2009 16:57
#318323
so i got a inspection on my bike today and of course it passed,
however the tyres are border line so i need front and rear tyres,
im not asking for Tyre recommendations just help determining the max
size the rims will take,
i have loads of clearance so width isn't the issue but just becouse i can get a 180 rear between my swing arm doesn't mean the Tyre won't misshapen because the rim isn't wide enough for the Tyre,
i currently have dymag 18''s on the front and rear running 110-80-18 and 160-60-18.
the front end could take a wider Tyre as could the rear however this may distort the sidewall of the Tyre.
so is there a magic math sum that determines a 3.25'' wide rim can only take tyres between 100 -120 and a 4.75 can take 120 - 140?
if so where do i measure rim width?
  • timebomb33
  • timebomb33's Avatar
Re: RIM SIZE = TYRE SIZE
01 Sep 2009 17:13
#318334
you measure rim width from inside of the bead to the inside of the other bead. with a 4.75 rim you should be able to use a 160 tire now the tough thing will be to get an 18 in that width
I THINK MY POWERBAND BROKE
01 Sep 2009 18:19
#318367
This may or may not help, but if you go to the link below you'll find the Dunlop Tire Fitment Guide. Try different model bikes and you'll see that for many of them it gives the front and rear rim width along with the recommended tire sizes. This may help you figure out the relationship between rim width and tire size. Ed
Fitment Guide
  • kano
01 Sep 2009 18:39
#318372
acording to his i have too big tires on my rims :S
01 Sep 2009 20:38
#318446
That chart doesn't show the rim sizes. It only shows the metric/alpha/inch conversion for each tire size. Take a lookk at the fitment chart in the link to see the rim size/ tire size relationships. Ed
  • bountyhunter
  • bountyhunter's Avatar
01 Sep 2009 22:57
#318476
On mine, stock is 3.25-19 front and closest metric equivalent is 100-90-19. 110-90-19 is definitely too big for my front.
My stock back was 4.00-18 and 110-90-18 is closest equivalent (about the same width, a shade less diameter). I believe 120-90-18 would be close to a 4.75 tire equivalent.
  • kano
02 Sep 2009 15:43 - 02 Sep 2009 15:49
#318650
so i rechecked my dymag rims and i am running.
its kinda hard to measure and to be honest my rim size measurements are probabley under true size.
rim size 3.25-3.50 on the front current tire 110/80-18
rim size 4.00-4.50 on the rear current tire 160/60-18
however the rear tire sidewall is defiantly distorted
probably becouse i put the 160 on it!
front tire looks good though?
so i ordered
110/90-18 FRONT - THE BRIDGESTONE SPITFIRE S11F
130/90-18 REAR - THE BRIDGESTONE SPITFIRE S11R
Last edit: 02 Sep 2009 15:49 by kano.
  • TexasKZ
  • TexasKZ's Avatar
02 Sep 2009 19:07
#318731
Don't know about Dymag, but stock wheels have the width cast into them.
  • kano
02 Sep 2009 19:28
#318735
unfortunately these dymags don't just my luck.
