Numbness Vibration....NO FUN
  • supermandaddy
  • supermandaddy's Avatar Topic Author
30 Aug 2009 09:01
#317556
I am getting numbness in my hands after riding more than 20 mins…..i have seen ant vibration kits and adders for handle bars….guys on forum said to shoot some silicone culking down the tubes and that should help….wondering if you guys heard of this or think the anti vibration kits work?
PS I may be adding bar end mirrors
Fort Worth, TX
1979 KZ650 C3
  • MFolks
  • MFolks's Avatar
Re: Numbness Vibration....NO FUN
30 Aug 2009 09:48
#317567
www.barsnake.com/ might work for you.
30 Aug 2009 09:50
#317568
Hello, James, and WELCOME to KZR! :)
We're glad you're here! :cheer:
:unsure: What bike, year and model?
May want to address the several other vibe producing suspects before resorting to the handlebars.
Good Luck! :)
  • chance
  • chance's Avatar
  • Life long biker/
30 Aug 2009 10:38 - 30 Aug 2009 10:39
#317580
Hi ..When your hands go numb after 20 mins, of riding it means you're getting old like me.:lol:
Last edit: 30 Aug 2009 10:39 by chance. Reason: misspelling
  • Vter Bob
  • Vter Bob's Avatar
30 Aug 2009 10:40
#317581
Things I would check if vibration is so bad you can't stand it after only 20 minutes:
1. Motor mounts - Make sure they are torqued to spec and if you have rubber mounts make sure they are not hardened, cracked or missing.
2. Chain - Make sure your chain & sprockets are not bad. Is chain to tight or does it have tight spots? Is it properly lubricated.
3. Carbs - Are the carbs properly synched?
I'm sure there are a few other things that can cause excessive vibrations (wheel bearings and rear wheel alignment come to mind) and somebody else will jump in with their ideas. Just my $.02
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
  • Locozuna
  • Locozuna's Avatar
30 Aug 2009 10:46
#317584
Adding bar ends may change the frequency of the vibes. Could be better could be worse. What bike model is it? Some are just vibrators. :woohoo: I have heard of both the bar snake and shooting silicone down them and heard testimony that both gave good results. But the guys are also spot on to make sure everything is tightened and your engine is tuned. Here's to good vibrations! GLuck!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • supermandaddy
30 Aug 2009 10:50
#317586
I am riding a 1979 KZ650C3, I have just installed new Bikemaster drag bars with some foam cushion grips and a new clutch cable from a 1977 KZ650B1 (which is about 4 inches shorter)....the reason for this info is that with factory bars did not have this issue.....thought about putting expanding foam in bars or even trying some rubber in between the bar and the bar mounts....I am a very budgeted rider so wanting to spend money if is known to be something that works
Fort Worth, TX
1979 KZ650 C3
  • Vter Bob
  • Vter Bob's Avatar
30 Aug 2009 11:14
#317600
The drag bars should be easy (but messy) to fill with silicone. I have also heard of people filling the bars with lead shot or BB's and that helping with vibration.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
  • Kawickrice
  • Kawickrice's Avatar
30 Aug 2009 11:27
#317604
My 650, 900 and GS1100 all do it to some extent. Usually around 4500 RPM is when mine is noticeable and tingly on the finger tips. I use fingerless riding glove with the padding on the palm for long trips and it help alot..... I haven't identified the reason on mine but most likely is I need to do some maintenance, but I ride frequently and rack up miles so I will do a valve adjustment soon and address all the yearly maintenance issues at once.... I also noticed when my fingers tingle I have a strong tight grip on the bars, if i loosen up it will go away. The position of your hands from drag bars also contribute. The position of your bars bending "UP" a little would kill my wrists because of the angle. Have you tried them pointed down to see if the angle of your wrist is more comfortable?
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • supermandaddy
30 Aug 2009 11:39
#317608
Yeah I am also thinking will have to get some gloves....bugs are killer and with winter coming up will be a good investment....I have not gotten to adjusting the bars much so that is something I will have to play with....I feel like I am sitting kind of high on the bike and have to lean forward which makes my palms a little sore....on longer trips I am finding myself taking my left hand off the bars more often than I need or would like to so the palm padding would be great...I am still curious if the silicone would be enough to subside the issues or if the investment of the bar snake would be a better cure
Fort Worth, TX
1979 KZ650 C3
  • Beatpoet
  • Beatpoet's Avatar
30 Aug 2009 12:07
#317613
I would think that adding weight to the moving steering assembly would be a last resort.
  • Grantl
  • Grantl's Avatar
  • KZRider is Da Bomb!!!
30 Aug 2009 20:07
#317746
Might not be the bike, it could be the position of your neck during riding has changed now that your bars are in a different position. All the nerves to your hands run up through your shoulders and through your neck muscles.
In your new riding position, you could be putting pressure on the nerves to your hands which makes your hands go numb. Just an idea since you mentioned changing bars.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
