Rear suspension lay out
  • perattzi
  • perattzi's Avatar
Re: Rear suspension lay out
31 Aug 2009 20:27
#318113
I'm at the same point with my 650 project...trying to figure out where to mount the shocks to my SV650 swingarm and how long they should be...and the affects on the rake/trail.
1978 KZ650B w/ Zuki running gear project
  • mark1122
  • mark1122's Avatar Topic Author
  • Keep twisting it
02 Sep 2009 19:54
#318751
from what I’m seeing now. i need shorter shocks for sure.
I just realized that since my swing arm is lower than it should be,(about 3.5" due to the shocks being too long) it is stretching the hell out of my chain. As the shocks compress over a bump , the chain gets tighter. If I adjust the chain to have 1.250" of slack and then compress the shock 3", the chain is sprung very tight. This explains why my chain has stretched sooo much.
If the swing arm pivot and axle are in line with the output shaft the chain will get looser as the shock goes up or down. :)
if the arm is above, or below this line the chain will get tighter.:(
Therefore, this seems to be the starting point. then u can find the optimum angle to get a progressive spring action (as the shock compresses it gets harder to compress, rather than linier.)
Thanks for the help Leon.B) i sent u an email.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
03 Sep 2009 07:42
#318838
happy to help,mark.
leon holmes
