Rear suspension lay out
- mark1122
- Keep twisting it
24 Aug 2009 08:59
Does anyone have a book or info on rear suspension layout?
I have a 76 kz900, with a 95 zx9 front end and a 02 zrx12 rear end. the rear shocks are too long to achieve a level riding bike.
Is the swing arms rear axle supposed to be in line with the pivot axle and drive sprocket centers at rest?
what would the optimum shock angle be? Is it advantageous to mount the lower shock mount as far away from the rear axle as possible?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
Re: Rear suspension lay out
24 Aug 2009 15:24
i say they look best when theyre about level with pivot when loaded
- timebomb33
24 Aug 2009 15:29
tony foale has a book out on chassis design.
I THINK MY POWERBAND BROKE
- PLUMMEN
24 Aug 2009 19:07
timebomb33 wrote:
ah forget tony,go for the looks! :woohoo:tony foale has a book out on chassis design.
- mark1122
- Keep twisting it
24 Aug 2009 19:38
anyone have Tony Foale's book?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
24 Aug 2009 21:14
im no engineer but i would think having it as close to centerline as possible would be best since that is what youre trying to control and i would think that is the point where the most torque is being appied to the swingarm trying to basically fold it over.i would also try to keep in mind the arc that the swingarm pivots in and try to keep the shocks in position where they can compress and rebound instead of trying to bend themselves.
- mark1122
- Keep twisting it
25 Aug 2009 05:06
That makes good sense.
I do believe that a straight line between the 3 points would be best with the rider on the bike. I would really like to find out more about the best position for the shock.
I have read that there is an optimum lean angle. It will make the spring compression the most progressive. On either side of that angle it can be positive negative or even both.
Also, the shock mounts position, will have an influence on the amount of leverage applied. As 1 (top , or bottom) is moved in it will create more leverage .
I need to learn more about this so i can set it up right and buy the appropriate length shock.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
25 Aug 2009 09:29
here is the link to tony's steering geometry calculator.it is freeware,hth.
www.tonyfoale.com/
leon holmes
www.tonyfoale.com/
leon holmes
- mark1122
- Keep twisting it
25 Aug 2009 11:17
Thanks Leon.
the rake doesn’t seem to matter that much. i have had the rear end up and the bike at a level stance. this changed the rake from 22.5* to 26*. the bike handles fine either way.
i prefer it at a level stance though. when the back end is high it is not as comfy to ride. it puts weight on my wrists, and makes me slide towards the tank. so i would like to lower the rear with shorter shocks. i just thought it would be good to figure out the best setup geometry, for the rear shocks, before i make any purchases.
so i need more info on the rear end geometry.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
26 Aug 2009 09:39
ahsa.
leon holmes
leon holmes
- mark1122
- Keep twisting it
26 Aug 2009 13:36
531blackbanshee wrote:
Sory i'm slow. "ahsa" ??:side:
ahsa.
leon holmes
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
26 Aug 2009 19:07
ahsa=i see senior.haha!
i have asked the members of the motorcycle chassis design e-mail list if they could help us with your problem.if they come back with any help i will let you know.
leon holmes
leon holmes
