front end vibration
- fyrfyter1804
front end vibration
23 Aug 2009 12:44
Hi,
Just was curious if anybody has any ideas for me. I have a 1981 kz650 csr, it has a rhythmic bouncing in the front end, or at least it feels that way. I needed to replace the fork seals anyway so I changed them and the oil and adjusted air pressure, no difference. It seems to be worse at lower speeds than cruising, and it does it on a brand new perfectly flat road. any possibility the chain and sprockets would cause this? Also front tire is new and balanced, and everything seems tight.
Thanks
Thanks
- MFolks
Re: front end vibration
23 Aug 2009 14:05
Chains and sprockets can develope tight spots. To check this,put the bike on the centerstand(if you have one) and spin the back wheel looking for out of round condition on the rear sprocket.
Have you spun the front wheel, again looking for an out of round wheel? Possibly wheel bearings are going.
- trianglelaguna
23 Aug 2009 14:34
rear wheel straight in the swingarm?
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- Kawickrice
23 Aug 2009 14:38
Sometimes when you mount a tire, it can be seated wrong when you pump it full of air. There is usually a raised line moulded into the tire that is right where the tire meets the rim that will show this. This is usually not the case if it has been balanced correctly. If a shop did the work it would be worth checking.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- fyrfyter1804
09 Sep 2009 19:20
Just curious.....Is the steering supposed to "detent" to the center position. Mine does this and I am wondering if this could be causing my problem.
Thanks
Thanks
- trianglelaguna
09 Sep 2009 19:23
explain detent....more details
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
09 Sep 2009 19:49 - 09 Sep 2009 19:53
fyrfyter1804 wrote:
"detent" to the center position may indicate the ball bearings in the steering stem are no longer rolling smoothly in their races. Tightening usually doesn't remedy the condition. Many owners have converted to tapered bearings for better longevity. However, could be wrong but don't suspect the "detent" is causing the rhythmic bouncing in the front end.
Perhaps a warped front brake disc rotor might possibly cause the brakes to drag and produce a pulsing sensation.
As earlier mentioned, would look at front tire mounting, and balance, and assure tire isn't out-of-round. All in addition to the drive chain condition and alignment, and rear wheel matters previously noted.
Good Luck!
...1981 kz650 csr, it has a rhythmic bouncing in the front end...worse at lower speeds than cruising, and it does it on a brand new perfectly flat road...
Just curious.....Is the steering supposed to "detent" to the center position. Mine does this and I am wondering if this could be causing my problem....
Good Luck!
Last edit: 09 Sep 2009 19:53 by Patton.
- WABBMW
- Let The Good Times Roll !
22 Sep 2009 07:41
fyrfyter1804:
I had the same problem that was most noticable at about 40 MPH. It would practically go away below 25 and above about 50. Both tires had been balanced. The front tire was out of round by about 1/16", more on one side than the other. The rear tire was about 1/8" out of round and somewhat irregular when rotated.
Then I got new tires and wheels. THE PROBLEM COMPLETELY WENT AWAY. The previous wheels ran very true, so it was not the wheels. I put the old front tire and wheel back on - no bouncing or wobble. Took it back off, put the new front tire on, and put the old rear wheel & tire on - The wobble was back!
So my wonderful Kenda Challenger rear tire was causing the front to wobble up and down. The tire must have also had hard and soft spots around the circumference, in addition to the out of round. With the new tires, the whole ride is so much more pleasant and controlled.
The steering detent situation is where the balls eventually beat small notches in the bearing races, mostly in the straight ahead position. This occurs due to riding on rough roads, or out of round or out of balance tire, or, as I did, by over tightening the steering bearings. This might slightly aggrevate the situation, but I do not believe is the primary cause of the wobble or vibration. Mine has this and I plan to install tapered roller bearings soon.
The Kenda Challengers gave high mileage, and average traction, but were not manufactured to very high standards regarding roundness and uniformity, in my opinion. Hope this helps.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
- Sandy
- Fly High,Tony
22 Sep 2009 07:54
Might be time to do an engine tune-up,synch carbs,adjust valves etc.
1977 KZ1000 A-1
- chance
- Life long biker/
22 Sep 2009 15:32
Sound like everyone has got you covered. Just one thing I know of I rub my hand oner the tires and can feel flat spots or bumps they should feel smooth plus a visual inspection. I found a lot of shakers on bikes and cars.
