Extended GS arm
- jaycaffee
Extended GS arm
15 Aug 2009 07:41 - 15 Aug 2009 07:42
Can anybody tell me where I can find some good pics of GS arm's that have been extended? I'm thinking about streching one for my 77 KZ 1000 project and would like to get some Ideas and check out how to brace it. Yes, I do have a highly qualifed tig welder lined up. Thanks for any help and/or advice.
Last edit: 15 Aug 2009 07:42 by jaycaffee.
- PLUMMEN
Re: Extended GS arm
15 Aug 2009 10:56
the gs arms from early 80s are kind of odd ball as far as the tubing goes,might be a little hard to match up.the newer sportbike arms are really easy to come by and are easily extended
- jaycaffee
Re: Extended GS arm
15 Aug 2009 20:18
It's odd alright. Is there a particular arm that fits a 77 1000a better than another? ZX?
- will61310
Re: Extended GS arm
15 Aug 2009 23:01
i think alot of it depends on what you plan on using for the rear wheel also. are you going with a fat tire?
...1980 LTD 1000...
- Peterbilt
Re: Extended GS arm
16 Aug 2009 01:40 - 16 Aug 2009 01:55
I've been thinking about a new swing arm this year also. A GS? A ZRX? If money were no issue I think I would go with a after market, direct bolt on like the German made arm American Classix is selling or a JMC arm at swingarm.com and there are other company's like trac dynamics or Mcintosh selling aftermarket arms that are direct bolt on, some extended and some braced. Prices are from $750 to well over a grand. Ouch!!!
76 KZ 900 A4 Andrews 2x cams V@H exhaust 28mm Mikuni carbs off a KZ1000 rejected with accelerator pump removed and pod filters
Last edit: 16 Aug 2009 01:55 by Peterbilt.
- jaycaffee
Re: Extended GS arm
16 Aug 2009 07:38
In a perfect world I would have a 5.5" Slick, but I at least want something close, but no huge wide tire. I'm really a noob at this (as if you couldnt tell) and thought the width of the GS arm would handle it. I'm on a really tight budget, hence wanting to stretch the GS arm, but its an odd beast. I would like to find something that fits atleast as good as the GS arm, or if anybody has any good drawings, I could just build what I want. The whole point of this project is to have a nice 1/8th mile bracket bike.
Thanks again!!
Thanks again!!
- PLUMMEN
Re: Extended GS arm
16 Aug 2009 09:08
late 80s-early 90s suzuki gsxr 750-1100 is fairly easy,just weld shock mounts on and shim front
- jaycaffee
- PLUMMEN
Re: Extended GS arm
16 Aug 2009 13:20 - 16 Aug 2009 13:50
i had pictures of a gsxr arm i modified someplace,ill see iff i can find them
i dont think an extended swingarm did it for this guy,reminds me of riding my 1st turbo project! :woohoo:
Last edit: 16 Aug 2009 13:50 by PLUMMEN.
