loose front caliper
- Davestradamus
loose front caliper
12 Aug 2009 12:56
my front brake caliper feels loose. it has a tiny bit of play from side to side, is this normal? i have tried tightening all the visible bolts/screws to no avail. HELP! i do not want my caliper to fly off leaving me in a guardrail or something.
thanks!
david
thanks!
david
- trianglelaguna
Re: loose front caliper
12 Aug 2009 13:07 - 12 Aug 2009 13:10
if your pads are thick it should not flop around...if your pads are ready for a replace,,,,it still should not flop around but rather ,be weak and squeeky even.....your caliper works by sliding two halfs towrards each other...one is fixed to the fork leg and the other moves on the slide bolts or carrier blots...which by the way need greasing when the brake is serviced.....the only thing i can think of is that your pads have enough to allow excessive sliding of the one half under brake onset.......does this help at all......by the way ,i know very little ,so wait for a second answer....:laugh:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
Last edit: 12 Aug 2009 13:10 by trianglelaguna.
