'80 KZ1000 LTD shock disassembly
- sbulla
- 1980 KZ1000 LTD
07 Aug 2009 07:50
Anyone know how these come apart? I have spring compressors that'll handle the springs but, I can't see under that cap at the top to see how they are held in place. That cap is also the "rebound adjustment".
Sonny
Sonny
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- TerryK
Re: '80 KZ1000 LTD shock disassembly
07 Aug 2009 08:25
If I remember correctly, the eyes screw off....but I'm not 100% on that.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
07 Aug 2009 08:33
I seem to remember reading a thread about this a while back. Seems like the top mount is pinned on??
- TerryK
07 Aug 2009 08:35
TexasKZ wrote:
You may be right on that one.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- sbulla
- 1980 KZ1000 LTD
07 Aug 2009 08:57
TexasKZ wrote:
I saw a thread like that for a 650 shock when I searched but, they appeared to be different from mine.
I compressed the springs quite a bit but, couldn't get the cap to slide down even after disengaging it from the inner ring that guides it through the rebound settings. Maybe I didn't compress them far enough but, I would like to know what's under there before prying and possibly breaking something.
Sonny
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- sbulla
- 1980 KZ1000 LTD
07 Aug 2009 15:24
OK. I got the top cap off and the spring. The pic shows a "U" pin that was holding the top cap retainer in place and, once it was removed the cap comes off the top.
If my eyes were a few (many) years younger, I would have seen this sooner.
Under the cap was your basic slotted spring keeper (not pictured).
Sonny
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- sbulla
- 1980 KZ1000 LTD
Re: '80 KZ1000 LTD shock disassembly...another ?
07 Aug 2009 15:30
Now that I have it apart this much, does anyone know if I unscrew the top mount with the rebound adjustment gears in it off the shaft, will I be losing some pressure?
Are these gas shocks or just oil type? Does that adjustment have some kind of rod that goes down the shaft to the shock body?
Sonny
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- sbulla
- 1980 KZ1000 LTD
Re: '80 KZ1000 LTD shock disassembly-DONE!
09 Aug 2009 07:26
Finally got the shocks apart so, here's a breakdown if anyone else ever wants to try this. This is the main breakdown...
Sonny
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- sbulla
- 1980 KZ1000 LTD
09 Aug 2009 07:29
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- sbulla
- 1980 KZ1000 LTD
09 Aug 2009 07:31
...and here's the compressors I used to squish the springs. They worked real good. Got 'em off e-bay from "sportingforless".
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- JMKZHI
- Mcdroid
- Gone Kwackers
09 Aug 2009 09:42
I call that 'excellent' and raise you a 'wonderful'. Thanks!
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
