Front end feels uneasy, please help
- roy-b-boy-b
Re: Front end feels uneasy, please help
04 Aug 2009 15:24
Do you have a camera so you can post pictures?
My bikes have two kinds of caps one that has a square fitting and one that i have to make a tool for removal by welding two bolts together.
I'm sure you can do a search and answer a lot of the questions you have. Roy
- comppro2k7
- comppro2k7
04 Aug 2009 15:46 - 04 Aug 2009 15:47
Last edit: 04 Aug 2009 15:47 by comppro2k7.
- JMKZHI
04 Aug 2009 16:21
comppro2k7 wrote:
JMKZHI wrote:i pulled off the rubber plugs on top of forks and its a solid metal plug under it, Ive never seen anything like it before.
There's a recent KZ750 Spectre fork tube plug topic.
- KawiConvert
04 Aug 2009 16:51
I believe you push it down and pull the snap ring out and then it comes out.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- Link14
05 Aug 2009 13:40
Those look exactly like the top plugs on my old 79 kz400.
The easiest way I found to pull the plugs was to get one person to push down on the plug with a big phillips head screw driver. The other person slips a thin bladed regular screwdriver under one end of the snapring and lifts it out so you can grip it with a pair of needlenose pliers. Gently pull up while pulling the end worked for me for the removal.
If you aren't planning on pulling the front shocks, you might want to consider flushing the shocks; just put the lower plugs back in, add some oil and rock up and down on the front a couple of times to loosen things up (don't look down the tubes while doing this....don't ask. Then drain.
My 82 kz750 manual says to use 10W oil in the shocks. I think next year I'll go to 15W or 20W, 'cause they're a little soft and I'm not too big (170 lbs).
The manual should give the amount of oil to use and how to check to see if there's enough. Good Luck!
- comppro2k7
06 Aug 2009 10:11
Thanks to all for the tips. i finally got the top caps off, not too bad with the right tools, the old fork fluid was nasty, prob original, put in new fluid and once i ride it, will update on if it helped out or not.
