Front Fork Space to rear required???
  • mzandmz
  • mzandmz's Avatar Topic Author
02 Aug 2009 21:50 - 02 Aug 2009 22:20
#310998
I replaced my front dust boots on the shocks and when I put on the front tire I noticed the axle clamps have a little space between them and the bottems of the shock tubes. I tightend the nuts according to what the book said. Is this normal.I made sure that the space(1mm front and back) was equal on each side of the axle clamps and the arrow on them points to the front. Seals are both good the dust boots were old and crack. previous owner replaced the seals and not the boots...Dumb. I like to do complete replacements so I know what I've got.
New to Family, 1979 KZ440 LTD
Last edit: 02 Aug 2009 22:20 by mzandmz.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Front Fork Question??
02 Aug 2009 22:07
#310999
normally space goes towards rear B)
  • mzandmz
02 Aug 2009 22:23
#311001
should it be to the rear. or will it hurt to leave it the way I put it? I thought even would be better so you have even tightness on both nuts.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
03 Aug 2009 01:20
#311089
You can still have the same torque on both nuts with the space to the rear. Roy
03 Aug 2009 01:31
#311092
Yes. On the axle clamps, gap is supposed to be only at the rear, with no gap at the front.
On each end of axle, should first tighten the front nut (no gap), and then tighten the rear nut (gap).
Good Luck! :)
