rear shock leaking oil
- terry s
01 Aug 2009 04:35
Is there a fix for a leaky shock other then relacement? I have a 1980 1000 ltd where is a reasonable priced supplier?
Re: rear shock leaking oil
01 Aug 2009 06:27
terry s wrote:
Z1 Enterprises has a nice selection.
Good Luck!
Good Luck!
- otakar
01 Aug 2009 07:56
OEM Kawasaki shocks are not rebuildable. Replacement is the only option. Z1 has OEM stile replacements or you can buy shocks from Progressive, which is what I did. The Chinese ones will cost you about a hundred bucks and the American "Progressive" will cost you about Two Fifty.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
01 Aug 2009 08:04 - 01 Aug 2009 08:13
I can vouch for the quality of these shocks and the seller (Dave Quinn) in personally setting them up for your specific requirements after discussing your riding style, weight, accessories, etc. I have them on my KZ650 and they are top quality in every respect. Bodies and shrouds are made of stainless steel. They're from Great Britain, Dave Quinn is the US distributor. Ed
Near the bottom of this link you can see different styles:
HAGON
HAGON
Last edit: 01 Aug 2009 08:13 by 650ed.
