Need a master cylinder reservoir
  • ambassadornchains
  • ambassadornchains's Avatar Topic Author
30 Jul 2009 20:31
#310479
There is a good chance that I need a new master cylinder reservoir for my KZ550. My question is, could I use one from another bike like maybe a honda, or yamaha, or do I have to get one for the KZ? There seems to be ton for other bikes that have smaller ones that look quite a bit better, and are quite a bit cheaper. I was just wondering, I might not need one at all. I will find out for sure by the weekend. Thanks.
  • TerryK
  • TerryK's Avatar
Re: Need a master cylinder reservoir
03 Aug 2009 23:01
#311428
You should be able to use just about any one that you can make work. Just make sure it is cleaned thoroughly of any fluid before you use it.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • JMKZHI
  • JMKZHI's Avatar
04 Aug 2009 06:04
#311468
You can use one from just about any Japanese bike.
Make sure it's for a single disk.
