installing superbike bars
- asevans
26 Jul 2009 18:32
ok. i want to put on some superbike bars. ive got stock kz900 bars. they are a little higher and come back farther than the superbikes. my problem is the master cylinder hits the speed gauge when i put the supers on. i believe my master cylinder is stock. if somebody has superbike bars on their kz900 can you tell me how you did it. thanx
1976 kz900 Mostly stock
1978 Z1-R Project
1978 Z1-R Project
- Locozuna
Re: installing superbike bars
27 Jul 2009 05:38
I put a set of risers on and it was still tight. Got Goodrich stainless lines and changed the banjo to come off at a different angle too. No simple solution except maybe getting new brake with remote(perched) reservoir? GLuck!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- 1973Z
27 Jul 2009 05:59
Just slightly loosen the handlebar clamp and rotate the bars back a little bit(so they aren't quite parallel with the fork tubes when viewed from the side)and adjust/rotate the throttle so the metal curved cable adjustment tubes won't hit your tank when the bars are turned all the way to the right. The brake cylinder can then be rotated on the bar so it's pretty well upright but clearing the guage. Rotate the clutch lever so it's the same angle as the brake lever. Mine has about a quarter to half inch of space between the brake cylinder and the tach.
- Russ Jackson
27 Jul 2009 07:10
Here is a picture of mine. The resevoir has been turned as you can see. It is a very tight fit...Russ
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
- asevans
30 Jul 2009 15:35
I got it. i had to turn the fitting off the master cylinder and fit it down under the tach. got the new shorter throttle cables coming.
1978 Z1-R Project
1978 Z1-R Project
- asevans
30 Jul 2009 16:20
1978 Z1-R Project
1978 Z1-R Project
