two nuts on valve stem, placement?
  • ujmrider
  • ujmrider's Avatar Topic Author
25 Jul 2009 20:25
#309319
I'm putting new tubes and tires on my 77 KZ1000. The new tubes came with T4 style valve stems with two nuts. Should one of the nuts be installed inside between the tube and rim,or should they both be outside where you can see them "double nutted" Does it even matter?
  • Motor Head
  • Motor Head's Avatar
Re: two nuts on valve stem, placement?
25 Jul 2009 20:28
#309322
Yea you got it right, 1- inside, 1- out. Holds the stem in place other wise you could tighten the outside one to much and rupture the tube.
  • The Garbone
  • The Garbone's Avatar
  • User is Currently waiting for his bailout check..
25 Jul 2009 20:31
#309324
Hmmmm,
:huh:
I thought the little convex metal washer went inside and the 2 nuts outside with the top nut keeping the lower nut from backing out over time...
I guess my setup might be wrong.....
2007 Royal Enfield Iron
1979 KZ650 & Hack
1949 Ford 8n
  • ujmrider
25 Jul 2009 20:32
#309326
Thanks. I'm on a budget and can't afford to ruin a new tube.
  • Motor Head
25 Jul 2009 20:34 - 25 Jul 2009 20:39
#309328
Washer on stem, then 1-nut. Then trough rim, 1-nut on the out side. Inner nut should be snug against washer but don't reef on it.
But I have seen the washer put on the outside or inside or rim between the 2 nuts.
Or maybe I'm going nuts?
Last edit: 25 Jul 2009 20:39 by Motor Head.
  • gane
  • gane's Avatar
26 Jul 2009 17:46
#309462
Agree, washer nut (finger tight) thru wheel then nut. quick tip, leave external nut slack, (just making contact)or leave out.outside nut keeps area clean and makes initial filling easier, being loose or absent allows a quick visual check for tire/tube spinning on wheel. a canted valve stem could warn you prior to ripping tube. g
[img][/img] 1977 KZ1000A1
