KZ1000 motor in a 650 frame, what would I need?
  • anarki650
  • anarki650's Avatar Topic Author
25 Jul 2009 12:46
#309268
Anyone here done this? Or know what it would take? I've seen a couple bikes on the web that are set up with the 1000 or 900 motor in the 650 frame so I know it's possible. I've got a line on a 1000 motor to replace mine with bad rings in #1, would end up costing me a lot less to get the motor than to put a big bore kit in my 650, so I'm really considering the swap but want to get some opinions on how difficult and what type of frame modification would be required to make it work. Obviously I'd have to gusset the frame, and I'm assuming stretch the motor mounts. Other than that, does anyone know if sprocket placement would be problematic? Or if the frame would need to be stretched at all to accept the 1000 motor?
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • oldkaws4ever
  • oldkaws4ever's Avatar
  • Have no regrets...... You only live once.
Re: KZ1000 motor in a 650 frame, what would I need?
25 Jul 2009 20:16
#309317
hey axton, im not sure on the frame mods, other than the gussets and different motor mounts. I do know that you will have to pull the 900/1000 motorto get the valve cover off. Other than that im not sure.......oh ya, it will haul major a**.....lol
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • KawiConvert
  • KawiConvert's Avatar
25 Jul 2009 20:26
#309321
If I remember right someone did this and posted on it about 6 months ago. Very shiny bike if I recall. They had to cut the frame and widen it to accommodate the 900 engine. It would be some work, and I'd lengthen the swingarm and install some kind of a seat stop to keep you on the bike.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
  • anarki650
25 Jul 2009 21:06
#309338
One of the guys over at kz650 info sent me a link to an archive post here where someone was talking about how they went about stuffing the motor in. Said they didn't have to cut the frame, just had to work the mounts and gusset the bejeezus out of it! Don't think I'd stretch her any, but would definitely brace the swing arm (or do a boxed swinger swap). Time will tell!!!
09 Kawasaki ER6n
Omaha NE
  • oldkaws4ever
25 Jul 2009 21:19
#309340
if you do the boxed swingarm swap, i would go with the gs 1100 arm, i have seen them on the 650's.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • Buda
  • Buda's Avatar
26 Jul 2009 05:37 - 26 Jul 2009 06:37
#309361
This is form kz650info.com
I just saw that picture of the GPz1100/z650 bike for sale in the UK - a very nice job indeed.
I started constructing a similar bike early last year, using a 1980 Z750 frame (basically identical to a 650 frame), and a Z1000J motor (fitted with 1100 pistons).
This bike has been built to use in local Historic racing, in a class known as 'Forgotten Era' - basically its a vintage Superbike class, and consists of production and GP bikes made between 1972 and 1980.
I managed to squeeze the big Z motor (which has the same external dimensions as the GPz series) into the 750 frame without too much difficulty. The cam cover has to be removed before the engine can be squeezed in, but originally I though the cams would have to be removed as well. They don't, which was a nice surprise.
A number of custom engine mounts were constructed from 10mm alumnium plate. The sump clears the lower frame rails with less than 2mm clearance each side, and there is less than 1.5mm clearance between the very rear of the motor and the swingarm (I am using a GSX1100 swingarm in this bike). I had to use a ZZR1100 front sprocket, which has the same spline pattern as the Z1000J motor, but is has a 19mm offset, so the chain lines up with the rear sprocket just nicely (less than 5mm clearance from the frame tubes - check the photos).
Tom
After I looked around awhile I see your a member over there.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Last edit: 26 Jul 2009 06:37 by Buda.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
26 Jul 2009 20:20
#309507
Here's a picture of that same GPz/Z650 I believe:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • anarki650
26 Jul 2009 21:27
#309511
After being schitzo about it for the last couple days I decided that the prospect of having a 1000 cc stuffed in the cafe is just too bad ass of an idea not to attempt. If all goes well I'll have the motor in hand by next week... I'll start a project thread then. Cheers!!
09 Kawasaki ER6n
Omaha NE
  • Kawickrice
  • Kawickrice's Avatar
26 Jul 2009 21:34
#309512
Go scitzo go B) B) B)
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • KawiConvert
26 Jul 2009 21:57
#309518
And I thought I was going out by plugging a 750 into my 650. I am looking forward to this build.
