Valve stem at the top of front forks
- pseudohermit
- I like to Vrrooom.
24 Jul 2009 10:26
I have a 1980 KZ1000 Shaft. When I bought it a few months ago, I noticed that there was a valve stem at the top of each front fork. They don't look stock, and I see no mention of them in my owner's manual. Does anyone have experience with these? I'm assuming it is some type of suspension control. I put a pressure gauge on them and they are showing no pressure.
Are they stock, or has someone modified the front forks? I'll attach a couple of pictures for clarity...
1980 KZ 1000 E2 Shaft
- pseudohermit
- Kawickrice
Re: Valve stem at the top of front forks
24 Jul 2009 10:42
If you put air in them use a hand pump not a compressor. It will not take much air pressure to blow the seals. As far as stock I could not tell you but others might be able to help you.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Mcdroid
- Gone Kwackers
24 Jul 2009 10:54
Kawrickrice is correct, add air with a bicycle pump. It is a low pressure system (8-10 lbs tops). And you are also correct...it is not stock to your bike...which means there may be no balance tube between the forks...which means you have to manually match the air pressure in each fork...handling will be troublesome if the pressures are markedly different...or you could leave them empty of pressure...that's how Kawasaki originally designed them
As an aside, what does that screw clamp in the picture do?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- pseudohermit
24 Jul 2009 11:17
Thanks for the advice, guys. I figured I'd better not blast it with the compressor until I figured out exactly what it was. The bike rides fine now, so I'll probably just leave it alone... Although the tinkerer in me really wants to mess around with it. We'll see...
Mcdroid, the screw clamp is part of the mounting system for my windshield (Streetshield EX, works great).
