New leaky fork seals.
- otakar
24 Jul 2009 07:49
OK- Last year about this time I completely rebuilt my front fork. It lasted less than a month and started to leak again. There is no pitting in the tubes and top bushing seams fine. I have a fork brace on it, so there is no flex. I have decided that i will change the fork seals again and maybe go to a heavier oil if I can find come. In the old days you could find oil to about 30W today the heaviest you can find is 20W. I feel that is too light for me. This is for my GPZ1100 and I feel the front end is too soft and it bottoms out all the time. I never use my rear brake, since it has almost no effect on the bike and the front fender hits the fearing lower mount every time that I brake hard. I have decided that I will expend the money and get a set of Progressive front springs. But it is the front seals that piss me off. I cant believe that Kawasaki seals are any different than the Bike Master seals. I have read from some of you guys who swear by OE seals. I cant understand why my left seal is perfect but the right is leaking since after the second or third week i put it in?????
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- JMKZHI
Re: New leaky fork seals.
24 Jul 2009 09:26 - 24 Jul 2009 09:26Believe it. The BikeMaster stuff is probably made in China or Taiwan.I cant believe that Kawasaki seals are any different than the Bike Master seals
Z1Enterprises sells K&L parts which are made in Japan & oem quality.
Last edit: 24 Jul 2009 09:26 by JMKZHI.
- gershom
24 Jul 2009 09:56
Only use seals OE branded fork seals. Leak Proof brand, means they will leak. I've never had an issue with OE seals, so why switch? Sure you can save a few dollars, but you'll be changing them often.
1978 KZ1000A2A, 1971 CB500K, 1972 CB350F, 1974 Guzzi 850T, 1974 Guzzi 850T, 1975 Guzzi 850T Hot Rod, 1966 BSA A65 Lightning, 1978 SR500
- Mcdroid
- Gone Kwackers
24 Jul 2009 10:02
Am I reading Otakar's post correctly? It doesn't matter whether he uses Kawasaki seals or Bike Master seals, they both leak? And it is the right seal that always leaks?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- otakar
24 Jul 2009 11:19
Mcdroid wrote:
NO. I replaced the seals a year ago and they were aftermarket. I never put in OE seals. OE seals are 8x of what aftermarket seals are. OE are $12 ea and AM are $7 for the pair.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- RonKZ650
24 Jul 2009 14:01
If you got a year out of the aftermarket ones you did pretty good. They never work. You'd think a seal would not be a delicate item needing to purchased through Kawasaki, but it is. I see several Yamaha's use the same size seal, but Yamaha is near twice the cost of original Kawasaki.
- JMKZHI
- otakar
24 Jul 2009 17:57 - 24 Jul 2009 18:05
I ordered two sets one from BikeBandit and one from Z1 The ons I installed were a set of British seals made by Pyramid-Parts those are the ons which are leaking. Or at least one is. I also ordered new front springs from Progressive. These should be a bit lighter at the very beginning but much stiffer toward the end. Also they come with preload spacers to make them as stiff as you want.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 24 Jul 2009 18:05 by otakar.
- otakar
27 Jul 2009 12:30
Got the first set of fork seals today. they came from Z1. They are made by K&S and are made in Formosa (
Let you figure that one out) First thing I noticed was that the rubber was quite a bit stiffer on these than on the "Pyramid" ones from england.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- JMKZHI
27 Jul 2009 13:06
Gee. It seems like Z1 no longer has the K&L seals. dang.
- JMKZHI
19 Aug 2009 08:49
I contacted Z1 this week. They can get OEM or K&L fork seals.
- sarge383
19 Aug 2009 10:02
have you taken a micrometer to the seal area of your leaky fork to check the amount of wear on it? after all you are dealing with a basic hydrulic cylinder.
kz 650d2 sr 79
