Frame modification
- clutch
- I wish I had a tad more patience to do it better!
Frame modification
23 Jul 2009 15:29
Hey guys,
I am seriously considering modifying my kz750 e standard a more cruiser style. I went to the extent of buying a 750 spectre rear fender and ordered the spectre rear grab bar. At this point, I realized I am going to have to chop the frame a bit. My question is that if I were to cut the very end of the frame off (just behind the blinker mount...pic provided), would it make the frame structurally unstable and unsafe????
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
Wish List:
- loudhvx
Re: Frame modification
23 Jul 2009 15:44 - 23 Jul 2009 15:46
That little plate at the very tail end helps to stop the tubes from "rolling" in turns etc. It's not super critical, though. My buddy chopped his e model there too and doesn't seem to mind too much.
If you weld a little brace across the where you chop it, that would help if you're worried. The existing brace there only helps to control bending, but not twisting, so you want something that stops the twisting. A small flat plate across the back of the cut tubes should do it.
If you really want the cruiser look, in the end, it will probably be cheaper and far less work to just get a non-running LTD.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 23 Jul 2009 15:46 by loudhvx.
- clutch
23 Jul 2009 15:49
I had a feeling it wouldn't be critical, but wanted to make sure. I wonder if the piece at the end will fit where I make the cuts with the new fender....
Thanks for the reply!
Wish List:
Wish List:
- clutch
23 Jul 2009 16:00
loudhvx wrote:
I don't know about cheaper...I can definitely find some CHEAP parts on eBay (and have). Maybe less work...but then again, not really if it doesn't run!
Wish List:
Wish List:
- loudhvx
23 Jul 2009 16:06
Depends on how far you want to go. I think that 18" wheel on the back may not pull off the cruiser look. It'll end up looking like a cafe bob.
The LTD should have a nice fat 16" wheel and the frame will already look appropriate for the wheel. The e model may just end up looking too tall in the middle and back. Of course you could chop up the frame too.
But you'll probably want the longer fork tubes of the LTD model too.
So it's hard to say really. IF the right LTD comes along it'd be a no brainer, but waiting for one may feel like an itch you can't scratch.
1981 KZ550 D1 gpz.
Other links.
Other links.
- loudhvx
23 Jul 2009 16:21 - 23 Jul 2009 16:27
Here's one by me, but kind of steep. But it's got the forks wheel and frame you probably want. He could probably be talked down with no title. Obviously too far for MD, but there may be some by you, especially in the fall.
chicago.craigslist.org/nwc/mcy/1277509978.html
When looking, make sure it's a four and not a twin, obviously.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 23 Jul 2009 16:27 by loudhvx.
- KawiConvert
23 Jul 2009 17:16
If you do weld a piece back in there, make sure it will clear the tire with the shocks compressed. Seems like a no brainer, but you'd be surprised.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- clutch
23 Jul 2009 17:35
KawiConvert wrote:
I checked, and it would be in the way of the spectre fender. Though, after thinking about it, the spectre rear grab bar will serve a similar purpose when securely installed. I think I will be ok without welding.
Wish List:
Wish List:
23 Jul 2009 17:41
Obviously I'm no expert, but looking at the diagram I would be a bit concerned about the possibility of the frame rails spreading under load where the top of the shocks mount. From the top of the shocks rearward there will be nothing but the little flat bridge to keep the frame geometry stable. If you cut the frame I would suggest that you weld a section of stiff tubing (old frame member?) to join the 2 ends of the frame rail so they can't become misaligned when you hit that unexpected pothole while knifing through a turn. Ed
- demonseed7
16 Aug 2009 20:37
i have the same bike kz750e and i made the same cut you are purposing, i haven't noticed any twisting or bending there, only thing i noticed was the tire was, is not centered between the frame, i suspect my bike has been dumped hard though. i went for the same look you mention'd you wanted, used a fendor and seat from a 65 harley, works great after the bugs were worked out, also welded a sissy bar into the open frame holes from the cut, well heres a pic of it so you can see what im talking about
- clutch
16 Aug 2009 21:11
demonseed,
Thanks TONS for your reply! Your bike looks great. Is your rear end lowered? If so...how did you do it? Also, it is hard to tell from that pic, but did you lower the front end by hiking up the forks higher into the tree? If so...how does it ride like that? I'm DYING to lower this bike. I love the clearance, but hate not being able to flat foot it at lights and stop signs. Oh...and as far as the off-center wheel. I think that is an old kz thing. My 80 kz 250 was slightly off, and my 82 kz750 is slightly off too.
Thanks,
Clutch
Thanks,
Clutch
Wish List:
Wish List:
- demonseed7
17 Aug 2009 03:04
no the rear is stock height. i do run into the occasionaly bottoming out of the fendor if i carry a passenger, so i just up'd the tension on my shocks. and the forks are "still" stock
