Engine mount bushings install question
- KawiConvert
Re: Engine mount bushings install question
30 Jul 2009 16:10
It sounds like you can, just don't remove them all at once.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- kano
- Not Another Bloody Limey!
30 Jul 2009 19:06
yes it is possible,
remove front bolts
loosen rear
with a bottle jack and a block of wood
raise the front remove and replace bushings
remove front bolts
loosen rear
- barney
01 Aug 2009 11:09
Thanks guys. I'll let you know how it goes
- PLUMMEN
01 Aug 2009 14:04
i guess this means ishouldnt spend a lot of time marketing the new remover/install tool! :laugh:
- barney
02 Aug 2009 17:13
Well Plummen. I will use something like you suggested if I cant do it with a brass punch. Thanks bud
