- Thank you received: 36
Engine mount bushings install question
- barney
20 Jul 2009 17:47 #308314
by barney
Engine mount bushings install question was created by barney
So I've ordered a complete set of rubber engine bushings(engine mounts) for an 81 GPZ1100 from the local Kawi dealer.
My question is: Can the mount bushings be changed out without removing the motor from the frame? It looks like I could if I removed the exhaust system, the gastank ,ignition coils/coil brackets and maybe the valve cover. Any input is appreciated.
Paul
Paul
- barney
23 Jul 2009 16:10 #308880
by barney
Replied by barney on topic Engine mount bushings install question
Anybody???
- barney
25 Jul 2009 09:36 #309251
by barney
81-83 1000j is the same. Anybody want to chime in ?
- 79MKII
- Love Them Kaws!
- Thank you received: 43
25 Jul 2009 11:49 #309262
by 79MKII
The Kaw List:
Replied by 79MKII on topic Engine mount bushings install question
I've never owned anything with rubber mounts - sorry. The older style mounts can be changed without engine removal, not sure about yours. Didn't realize they had rubber mounts to be honest. Hopefully someone will chime in...
The Kaw List:
- PLUMMEN
- Thank you received: 104
26 Jul 2009 08:13 #309380
by PLUMMEN
Replied by PLUMMEN on topic Engine mount bushings install question
ive never changed the mounts on a j series bike before,are the bushings in the motor?
- kano
- Not Another Bloody Limey!
26 Jul 2009 08:19 #309381
by kano
Replied by kano on topic Engine mount bushings install question
- barney
28 Jul 2009 14:37 #309898
by barney
Plummen to answer your question. Yes the J bikes have 4 cylindrical rubber vibration dampers which are pressed into the motor and 4 rubber disc dampers which reduce side vibration( see Kanos pic)
- PLUMMEN
28 Jul 2009 16:38 #309929
by PLUMMEN
iwonder if a guy could make some sort of press for installing/removing the bushings using a long piece of all-thread and a combination of nuts and flat washers
- kano
30 Jul 2009 14:37 #310404
by kano
i just pushed mine in with my little stumpy fingers!
didn't need any lube so shouldn't be too hard.
- PLUMMEN
30 Jul 2009 15:17 #310411
by PLUMMEN
show off! :laugh:
- kano
30 Jul 2009 15:19 #310412
by kano
- barney
30 Jul 2009 15:56 #310416
by barney
I guess I didnt explain properly. I know installing them isnt rocket science. I just wanted to know if anyone has been able to do the install with the motor in the frame. I was thinking if i removed the tank, coils and coil brackets and maybe valve cover and tilted the motor I could get at them. Dont really want to do all this if it wont work. Any of you ever done something like this?
