gs1100e axel
- toad
gs1100e axel
20 Jul 2009 05:38
ok I have pretty much everything to convert over my 78 kz1000 with a gs1100e swingarm but before I do will I be able to use my original swingarm axel or will I have to get one for the gs1100e? I can't find one anyway.Are there other axels that will work?Thanks
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- otakar
Re: gs1100e axel
20 Jul 2009 06:25 - 20 Jul 2009 06:34
I use the axle from a KZ/ZN1300 on mine. It fits perfectly, direct drop-in. The stock 1000 axle is too short. You will also have to get spacers to take up any extra gap on the wheel and also spacers for the pivot bolt. You will also have to use the torque link from a GS1100.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 20 Jul 2009 06:34 by otakar.
- toad
Re: gs1100e axel
20 Jul 2009 06:45
ok so the zn1300 axel is the same as the gs1100.I am going to be using a 4.5" gsxr rim, I will start looking for that axel and then change bearings/spacers as needed. Thanks again
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- toad
Re: gs1100e axel
20 Jul 2009 07:35
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- donthekawguy
Re: gs1100e axel
20 Jul 2009 22:50 - 21 Jul 2009 05:27
There are a bunch of places that have gs1100e axles. Do a search on one of those sites that hooks you up with a nationwide parts search. You will have at least 5 responces the next day. Like this one-
www.mrcycleparts.com/
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
Last edit: 21 Jul 2009 05:27 by donthekawguy.
- toad
Re: gs1100e axel
21 Jul 2009 17:09
thanks for the tips, I found one today.Now on to rear brake and front sprocket.
cheers
cheers
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
