1978 KZ650D1 Front brake master cylinder
  • markc3wa
  • markc3wa's Avatar Topic Author
19 Jul 2009 08:45
#308018
I've been unable to find a rebuild kit for this master cylinder. I've found them for many others but not this one. I'm looking for a source or advice about rebuilding this component.
Any help is gratefully appreciated!
  • fixer5000
  • fixer5000's Avatar
Re: 1978 KZ650D1 Front brake master cylinder
19 Jul 2009 10:29
#308031
in some cases you can take it apart, clean it up and reuse the old parts. is it leaking??
1978 kz650b pretty much stock
massachusetts
19 Jul 2009 10:42
#308034
If not already done, would try ordering any needed master cylinder parts through a Kaw dealer, because kawasaki.com shows the following oem parts as being still active (available):
Piston 43020-1023
Dust cover 49016-1010
Reservoir diaphragm 43028-1002
Sometimes, a master cylinder may be renovated by a thorough cleaning, dressing any pits inside the bore, and maybe a new piston.
Good Luck! :)
  • HerrDeacon
  • HerrDeacon's Avatar
19 Jul 2009 11:38
#308044
I ordered a rebuild kit for my D1 from Z1 Enterprises. It's only for the piston, not sure if they have the resevoir parts or not. It has worked perfectly and was very easy to install.
www.z1enterprises.com/SearchResult.aspx?...e&KeyWords=KL32-8052
19 Jul 2009 11:55 - 19 Jul 2009 12:01
#308045
That's some real good information, and the part number is consistent, but I missed seeing it when searching under Z1E's 1978 KZ650 parts listing, where it's omitted for some reason.
Shown under the quoted link is the following:
Master cylinder Rebuild Kit - double disk version (5/8")
KL32-8052
OEM: 43020-1023 49016-1010 43022-1001---
Contains all the parts to rebuild one (1) 5/8" master cylinder. This mastercylinder is typically used only for double disk setups. Given the age of these bikes, it is worth checking that the master cylinder is correct for the bike - most of these master cylinders will have 5/8" cast into the underneath of the master cylinder.
Fits KZ550-D1 KZ750E KZ750H KZ1000-A3 KZ1000-A4 KZ1000-B2 KZ1000-B3 KZ1000-B4 KZ1000C KZ1000E KZ1000G KZ1000-J1 KZ1000-J2 KZ1000K KZ1000M KZ1000-P1 thru P10 KZ1100-A1 KZ1100-A2 KZ1100-B1 KZ1300
$32.37
You betcha I would concur with Z1E as first choice inquiry! :cheer:
Good Luck! :)
Last edit: 19 Jul 2009 12:01 by Patton.
  • HerrDeacon
19 Jul 2009 18:18
#308095
Yeah, I couldn't find it under the '78 650 either. I think I searched for it and double checked with everyone on this site before I bought it.
Mark, is yours the trapezoid shaped MC with dual discs?
  • markc3wa
19 Jul 2009 20:09
#308133
Yeah, it's leaking. I think I'll need at least new o-rings.
  • markc3wa
19 Jul 2009 20:12
#308134
Yes, with the 5/8" stamped on the underside. I saw the part you mentioned @ Z1 and wondered if it would work.
  • markc3wa
19 Jul 2009 20:19
#308136
And the reservoir appears to be OK. It's leaking out of the brake lever end. I've have really good experiences with Z1. Thanks!
  • HerrDeacon
20 Jul 2009 03:01
#308177
That's where mine was leaking. Used to flick back while riding and it ruined my paint on the tank :(
The new piston kit fixed it perfectly.
  • kcam1999
  • kcam1999's Avatar
04 Nov 2009 09:44
#331483
I have the same problem, in the fact that my reservoir is leaking too. It leaks from the top, because the original gasket between the reservoir and the "lid" is now gone. Do you know where I might find just the gasket. I talked to Z1 and they said that it is no longer carried, by anybody. I need this to pass my inspection that is a month over due. Thanks so much for your help guys!
Kcam1999
kz 650
  • RonKZ650
  • RonKZ650's Avatar
04 Nov 2009 10:24
#331496
Kcam1999
There really isn't a gasket there since air must be allowed in to compensate for changes in the fluid level. How it's done is that accordian looking thing inside the master cylinder is vented to the outside air in the center only, the outside of it is sealed. It's a diaphram, so when the fluid goes down the accordian pulls down with it since air is allowed in the center. So in other words the accordian diaphram is the gasket and part number is 43028-1002 available through any kawasaki dealer.
