Steering Stabalizer - know how to put it on? Is it
- KOOL RYDER
- KZ 650B2 / KZ 1000E
16 Jul 2009 13:32
Anyone know how to mount a steering stabilizer on a 650B?
Are they a good add on?
Thanks
KR
Thanks
KR
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
1978 KZ650B
1979 KZ1000ST
- KZQ
- Administrator
Re: Steering Stabalizer - know how to put it on? Is
16 Jul 2009 13:41
I fitted a stabilizer to my KZ900 years ago and took it back off when I finally figured out that the head shake/wobble I was fighting was caused by worn swingarm bushings. I wouldn't imagine that the 650 is that much different in the frame geometry department.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- donthekawguy
16 Jul 2009 23:31
They sell brackets on ebay that bolt on to a fork leg and then you weld a piece on the frame to bolt it onto.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Bluemeanie
17 Jul 2009 06:01
Some go from the fork back to the right screw in reflecter hole on the down tube.
Re: Steering Stabalizer - know how to put it on? Is it
17 Jul 2009 06:06
Just curious - are you putting it on the bike to help compensate for an existing wobble or for some other reason? Ed
- 1973Z
17 Jul 2009 06:27
My '73 came stock with a bracket on the right hand frame down tube and a hole in the lower triple tree where the damper-s Kawasaki product itself-bolts right on. It's still there 36 years later and works just fine. It was the first accessory I installed when new, and I got it after some magazine articles at the time mentioned possible problems at high speed due to the frame being "under engineered" for the motor. I had it up to an indicated 125 mph once and it felt solid but I never took it up that fast again.
