kz 750 bore kit 810 rebuild question
  • Buachaillin
  • Buachaillin's Avatar Topic Author
16 Jul 2009 09:41
#307378
I just pulled the engine out of my 82 kz 750 spectre which has been bored out to an 810.
I am rebuilding it becuase it needs to cam chaing guides and a couple other things. I need new gaskets as well. My question is, with this bore kit on this do I need to find special gaskets to fit, or will the regular oem gaskets work good enough?
If I need aftermarket ones, does anyone know where I can find them?
thanks for the help, my engine is dismantled with parts everywhere, wa ha ha. dont worry, I kept them in good order though. B)
  • Tyler
  • Tyler's Avatar
Re: kz 750 bore kit 810 rebuild question
16 Jul 2009 13:35
#307417
Wiseco is most likely the manufacturer of the pistons in an 810cc displacement engine. If you go on thier website they list the part number for the head gasket. You can buy one from any distributor but they are not exactly cheap.
The head gasket is part no: W3163 and retails for $56.00
www.wiseco.com/Catalogs/Powersports/Kawa...leStreetOverbore.pdf
"74 Yamaha DT 400 Enduro
