'81 KZ550..what other model master cylinders fit?
  • crown_vick
  • crown_vick's Avatar Topic Author
14 Jul 2009 19:21
#307078
Well, rebuilt the caliper, but the master cylinder is seems to be seized with concrete. I'm guessing the master cylinder set-up is pretty general. Are there other models that will do the job and easy to find? Thanks for any help you can give.
  • jjdwoodman
  • jjdwoodman's Avatar
  • Live free, or die.
Re: '81 KZ550..what other model master cylinders fit?
14 Jul 2009 19:36
#307085
I'm not positive either, but I think most any mc that will clamp on the bars will work as long as they come off a similar sized caliper.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
  • JMKZHI
  • JMKZHI's Avatar
14 Jul 2009 19:49
#307091
Is the bike a 550-Ltd? Or a 550-A-Standard?
You can use a mc from just about any Japanese bike, including more modern models & Hondas, etc.
The basic criteria: 7/8" bars, mount angle (the Ltd mount is probably angled so that the reservoir will be level), single disk, mirror orifice. If you don't get a vintage Kaw unit, the brake lever may not match the other side unit & the brake lite wiring will have to be spliced.
If the bike is an Ltd, one from any 550-Ltd or KZ650-CSR should work. If the bike is a Standard, then one from any 550-A should work. Either way, there are porbably others as well. The underside of your mc is probably marked 1/2 which is the mc piston bore for single disk models (1/2").
  • djcody
  • djcody's Avatar
16 Jul 2009 16:39
#307454
Ebay has a pretty nice on thats brand new for about $50
77 KZ650C airpods and 4 into 2 turn outs exhaust. VM carbs
82 550 LTD all stock except air pods
  • JMKZHI
  • JMKZHI's Avatar
17 Jul 2009 05:50
#307533
Yep. usa-motorcycles-inc on ebbaayy sells a variety of new aftermarket units. I kinda recall one KZR member installing one & it woked fine. I don't know if Z1Enterprises.com can get them.
  • crown_vick
19 Jul 2009 17:41
#308086
Great, thanks for the help guys. The search is on...
