Would you ever run 2 clip type master links?
- savedrider
- 1975 Z1-B 900
13 Jul 2009 20:08
My father cut a chain off his bike and didn't know it actually had a clip type master link. The chain is a new DID630K chain and I wanted to use it, but found out DID doesn't sell a rivet type master link for this particular chain. I can only find clip type master links. So the only way would be to use 2 clip type master links. I don't like clip type links anyway, but 2 of them sounds like double trouble. Anyone ever do this, what are your thoughts? I'll probably just buy another chain, but I hate to discard this one since it's practically brand new (<50 miles).
Get right or get left! <*{{{><
- bountyhunter
Re: Would you ever run 2 clip type master links?
13 Jul 2009 21:13
A master link is only 1/2 of a full link set. To add two master links, you also need the inner link to connect them which does not come with a master link.
- bountyhunter
13 Jul 2009 21:15
OK, I reread it and I think you mean he cut one of the "outer" links which you could replace with a master link.
I don't think using two master links is much different than using one. I've run master link chains for the last 30 years and had no problem.
- savedrider
- 1975 Z1-B 900
13 Jul 2009 21:26
Good point on the inner link! I will have to check and see if I still have that. If not, looks like it's a no go.
- savedrider
- 1975 Z1-B 900
14 Jul 2009 00:56
Darn it, he cut the inner link! Oh well, guess I'll be waiting a bit longer before I get my Z1 back on the road.
- Old Man Rock
14 Jul 2009 04:37
As your profile name depicts... Safe-D-Rider...
Buy a new chain and you won't have to worry about it
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- bountyhunter
14 Jul 2009 14:03
Z1 Enterprises has the lowest prices on chains and sprockets.
