A lesson learned.
- wireman
- twowheeledterror
Re: A lesson learned.
13 Mar 2006 22:13
wireman wrote:
Galvanized sheet. 26/28 ga.
You clean it with hydrocloric before you tack and run a solder line onto it like a lap weld.
what are you guys soldering that you use acid on?
- Duck
- e vica na i sau na ga
14 Mar 2006 02:56
What solder alloy are you using on galvanized?
I've been doing electronics Sn63Pb37(eutectic) for over 40 years but haven't done any galvanized since middle school shop class and don't remember what we used.
-Duck
-Duck
- twowheeledterror
14 Mar 2006 06:03
Duck wrote:
It's HVAC, so usually just standard 50/50 lead/tin solder. I don't know a whole ton about it cause I don't do a lot of it. In fact, I try to do as little as possible cause I despose working with thin crap like that. It's not nearly as good a time as working with thick plate!
-Duck
- wireman
14 Mar 2006 07:20
i dont remember seeing any soldered ductwork in years .everything is done with pittsbourghs,s's,and drives.working with 26 and 28 ga aint that bad .you can actually cut it with tin snips and work it with simple hand tools and its good for making patterns for heavier projects.:whistle:
- twowheeledterror
14 Mar 2006 07:24
wireman wrote:
It's generally used for sealing in seams. :thumbup:
- wireman
14 Mar 2006 07:50
if you put ductwork together right theres no need for it ,spotwelded joints get a little duct seal brushed on if you dont put them together right.flexable joints might get a little clear silicone to allow for flex.but thats about it for sealing.:whistle:
- twowheeledterror
14 Mar 2006 08:00
wireman wrote:
Spotwelds aren't gonna seal against leakage, now are they?
There's time when you would use a Solder along a seam to make it tight enough that it won't leak.
Here's the tool you use.
The point is heated and then flux is added to it before you apply a 50/50 solder (or whatever tin content you require) to a seam or joint with it.
- wireman
14 Mar 2006 08:06
wireman said
Post edited by: steell, at: 2006/03/14 16:58
- twowheeledterror
14 Mar 2006 08:09
And then twowheeledterror said
Post edited by: steell, at: 2006/03/14 16:59
- twowheeledterror
14 Mar 2006 08:22
But twowheeledterror wasn't done yet, so he said some more
Post edited by: steell, at: 2006/03/14 17:00
- wireman
14 Mar 2006 08:37
And wireman replied
Post edited by: steell, at: 2006/03/14 17:01
