Rear Brake Locked Up
- zkellogg
03 Jul 2009 13:47
I was out riding today when the rear brake locked up on me. I wasn't moving very quickly when it happened and it didn't cause an accident or anything, but it was difficult getting back home as starting from a stop required lots of throttle and burning the clutch. Pedal was firm like it had been pumped up (like when you're bleeding the brakes). When I got home the rear caliper/pad was smoking. I was able to unlock the brake by cracking open the bleed nipple. The rear still feels like it's dragging. Any suggestions?
1977 KZ1000
- bountyhunter
Re: Rear Brake Locked Up
03 Jul 2009 14:01 - 03 Jul 2009 14:03
I would try flushing the fluid and bleeding it to make sure there is nothing funky in the line. If it still hangs up, I would guess a problem with the master cylinder or caliper piston assembly.
One other thing is to make sure the caliper assy is free to slide on the pins. My wife;s car started dragging the front bakes and it was because the grease they used on the pins had congealed and was hanging up the caliper. As the pads got hot and expanded, the brakes would drag.
Last edit: 03 Jul 2009 14:03 by bountyhunter.
03 Jul 2009 14:47
Would also adjust brake rod for more gap before contacting m/c piston upon depressing brake pedal.
Good Luck!
Good Luck!
- PLUMMEN
03 Jul 2009 15:10
check the little supply/return hole in bottem of mastercylinder to see if its plugged with something not allowing fluid to return.also check your brake pads and flush your fluid as im sure all that heat didnt do them any favors
- wrangler615
03 Jul 2009 15:27
If you could crack the bleeder and release the pressure it sounds like a problem with the master or line. Sometimes a softline can break down internally and get what acts like a check valve inside of it. To narrow down between line or master, try cracking the line loose at the master and see if it relieves pressure there. If so, suspect master. If not, suspect line.
83 Kaw KZ750F1 - massive money pit
82 Zuki GS1100G - my daily driver, possible sacrilege I know
- zkellogg
03 Jul 2009 16:40
Thanks guys, I'm going to get into it tonight and I'll report back.
1977 KZ1000
- PLUMMEN
04 Jul 2009 12:35
well whats the news?
- zkellogg
04 Jul 2009 22:21
Drained the brake fluid and refilled/bled the brake. Took it for a quick spin around the block and everything seems normal. I need to test it when it's really hot out like it was yesterday when it locked up. I'm almost wondering if the old brake fluid was breaking down and expanding in the lines. The fluid appeared to be in pretty bad shape. I went back with DOT 4 that should hold up to more heat.
1977 KZ1000
