Swingarm \"Buttons\"
  • indykaw77
  • indykaw77's Avatar Topic Author
12 Mar 2006 12:30
#30387
You guys and gals know what these are, right? Do these just screw into a hole in the swingarm (doesnt seem to me like the "point" would hold the weight??), or is a nut or fitting welded to the swingarm, then a lift post threaded into that, or what??
I'm trying to figure best way for the swingarm stand I
just welded up to pick the bike up. Are these "buttons" available for our older kaws??
Thanks....
Kawasaki Motorcycles...because cars lean th wrong way!
  • DanOz7Five0
  • DanOz7Five0's Avatar
Re: Swingarm \"Buttons\"
12 Mar 2006 19:19
#30475
Im lost but are they like a pad on the bottom of the swingarm so it doesnt get scratched when lifting it?
  • 77KZ650
  • 77KZ650's Avatar
12 Mar 2006 20:32
#30509
These things? I've seen them called spools, or sliders
07 MDP Rookie of the Year
  • wireman
  • wireman's Avatar
12 Mar 2006 20:45
#30515
you guys can fight over the spool/slider things,all i want is the caliper and bracket off that back wheel!:woohoo:
  • indykaw77
13 Mar 2006 03:14
#30548
77KZ650.....THEM'S the ones!!!! That looks like the nut is welded to underside of swingarm, then the button/spool/slider threads in there......hmmmmm.
Well...back to the drawing board:S
  • racer54
  • racer54's Avatar
13 Mar 2006 14:49
#30741
Them "things" are "bungs" used to fit into the end of a "sportbike" style lift/stand to lift and hold the rear wheel off ground for whatever you have in mind. Those stand usually come in two versions...one with a "U" shaped end to fit those "things" and another end that has a "flat" angle piece to be used on square-tubed swingarms.
  • 77KZ650
  • 77KZ650's Avatar
Re: Swingarm
13 Mar 2006 17:25
#30793
My ZX arm came with them welded on from the factory ( I assume, it still has factory paint, and the welds look the same all over the arm) its not a nut (its more of a "U" shape), but if you were making your own, a nut would do the exact same thing:)
Scott
