Battery fluid leaking
  • chrispysaki
  • chrispysaki's Avatar Topic Author
02 Jul 2009 08:07
#303863
I just did the wg coil mod, and I noticed that the chain guard, battery box and some other parts are getting caked with a white powdery gunk that looks to be coming from the battery.
I didn't notice this problem before doing the coil mod, but that doesn't necessarily mean it wasn't happening. One thing to note, when I did the mod, I connected the wire directly to the battery's positive terminal rather than the starter (which the instructions call for).
Can someone tell me what this white gunk is, if it's serious problem and how I can stop it?
Thanks,
Chris
Re: Battery fluid leaking
02 Jul 2009 11:10
#303884
You should have a battery vent/overflow tube connected to the battery vent orifice and routed down behind the engine to prevent any damage by an overcharged or overfilled battery. Ed
  • Kawickrice
  • Kawickrice's Avatar
02 Jul 2009 11:12
#303885
The white gunk is from the battery (acid). To stop it from trashing the bike you need to put the overflow tube on the battery and route it down and away from everything.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • chrispysaki
02 Jul 2009 11:32
#303888
I have a tube from an old battery I'll put on the overflow/vent nozzle. Do I need to be worried about the fact that it's venting?
  • MFolks
  • MFolks's Avatar
02 Jul 2009 12:12
#303893
If the fluid level is between the high and low marks, I'd put a multimeter on the battery terminals when the bike is at idle and see what the voltage is. If it's 14 volts or more, your system may be over charging.
www.electrosport.com has a trouble shooting page that will walk you through this test.
  • bountyhunter
  • bountyhunter's Avatar
02 Jul 2009 13:18
#303904
Measure the batt voltage with the engine revved to about 3k. It should be about 14 - 14.5V. If higher, your reg is overcharging the battery and boiling it out.
