Stretched Chain Question
  • coydogg
  • coydogg's Avatar Topic Author
01 Jul 2009 20:54
#303782
I think my bike is ready for a new chain. I was just wondering how far some of you guys will push a stretched chain? Me and my friends were going to go on a 700 mile round trip (Salt Lake, UT to Durango, CO) this weekend leaving friday morning. I just dont know if I should keep pushing my chain or not. My options are go on the ride with my bad chain or not go and get a new chain.
  • MFolks
  • MFolks's Avatar
Re: Stretched Chain Question
01 Jul 2009 21:17
#303789
When you replace the chain, do the sprockets too. Old parts will quickly wear out the new ones.
  • bountyhunter
  • bountyhunter's Avatar
01 Jul 2009 21:27
#303792
The problem with worn chains is they get loose spots which means they might hop off at a bad time. Hard to say how bad yours is.
  • coydogg
01 Jul 2009 21:38
#303795
it is pretty consistant in its looseness. I have rolled it all the way around and felt the tension and one spot gets a little tighter but not much.
Is a chain for a 78 kz 1000 something that I will just be able to get at a local shop? Cause if thats the case I might be able to take my bike in and get a new chain and still be able to go on my ride. I just dont have a chain breaker or anything to do it myself.
  • Z1109R Fin
  • Z1109R Fin's Avatar
02 Jul 2009 00:19
#303808
Yes, you´ll find good chains in most of bike shops. Get both new sprockets and a chain at the same time otherwise you´ll wear out the new chain very fast. They are a combo.
Z1000R ´83...Slightly modified...
02 Jul 2009 11:23
#303887
When is the last time it was adjusted and was that performed properly (about 1" play at tightest spot)?
  • bountyhunter
02 Jul 2009 13:20
#303905
Z1 enterprises can sell you a very good chain and sprockets for a lot less than local shops will. Believe me, I looked around (even on the net) before I bought mine.
  • bountyhunter
02 Jul 2009 13:23
#303906
The only way to know if it has reached it's death is to measure stretch by hanging a weight on it and measuring between a fixed number of links. I think they allow maybe 2% stretch? More than that and the rollers are not engaging the gears properly and grind the teeth off the gears.
  • saltydog
  • saltydog's Avatar
02 Jul 2009 15:49
#303929
stupid question. If it won't make the trip, get a new one. Probaly need new sprockets, also.
1981 KZ1000 CSR, 1982 KZ440 ltd, 1972 Honda ct90, 1978 KZ 650
  • hoghaterkaw
  • hoghaterkaw's Avatar
02 Jul 2009 18:50
#303970
a quick and dirty chain check. adjust the chain to the correct slack. then at the back sprocket pull the chain away from the sprocket in a straight line from the output sprocket. if you can lift the chain more than half the tooth depth your chain needs replaced.
  • Z1109R Fin
03 Jul 2009 01:58 - 03 Jul 2009 02:00
#304038
Stupid answer :P
NOT probably! It´s a MUST to change chain and sprockets at the same time. Sprockets wear out and they don´t fit new chain exactly and the new chain will wear out in no time.
Last edit: 03 Jul 2009 02:00 by Z1109R Fin.
  • halkaloogie
  • halkaloogie's Avatar
03 Jul 2009 20:49
#304272
It's false that sprockets and chains wear out at the same intervals. Chains are stupid things and can wear out quickly I have a KZ1000 and it will go through a non roller chain in a few weeks meaning it will stretch over 2 inches due to the low end torch> you should change both sprockets at the same time
