Chain Question
  • coydogg
  • coydogg's Avatar Topic Author
Chain Question
30 Jun 2009 17:57
#303467
I have a 78 KZ1000 that has been chopped up. Anyways my rear fender is off of an old Harley. My probelm is when I hit a bump my tail light mount is hitting my tire. I am talking maybe a 1/16-1/8 of an inch and it is starting to scar my new tire. Where my axel is sitting right now is at least an inch or so from the saddles on the swing arm. And my adjusters are almost all the way tapped out. I was wondering if I might be able to just take a link out of my chain which would kick my tire in and get rid of my problem. Would this work or not? I hope it does it will sure be alot easier then rigging up a whole new tail light setup.
  • Vter Bob
  • Vter Bob's Avatar
Re: Chain Question
30 Jun 2009 18:42
#303480
Is your chain badly stretched? If so I'd think about replacing it and both sprockets at the same time. If the chain isn't stretched and the sprockets are good, perhaps a non-stock sprocket was used (to change the gear ratio) in which case I don't see a problem removing one link. Oh, does your chain use a clip type master link?
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
  • coydogg
Re: Chain Question
30 Jun 2009 19:00
#303488
Now that you mention it, I am wondering if my chain might be a coming to the end of its life. I got a new tire and when I put it on I set the chain with about 1 1/2 inch play about a week later I had about 2-2 1/2 inches. I adjusted it again with about 1 1/2 inch play and I rode probably about 400 miles this last weekend and it seems that it is around 2 inches of play. Maybe I should get a new chain and see were that puts my tire and if I need have a link taken out. Hope there not to spendy I havent had to buy a motorcycle chain before. My rear sprocket apears to be in good condition, there is no play in it and the teeth all look pretty good.
  • Vter Bob
  • Vter Bob's Avatar
Re: Chain Question
02 Jul 2009 03:35
#303813
Give the good folks at Z1 Enterprises a call. I shopped around and found them to be the best priced for my KZ 1000 chain. If your chain is that stretched I would strongly recommend doing the sprockets also. Even slightly worn sprockets will shorten your chains life a bunch.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
  • KawiConvert
  • KawiConvert's Avatar
Re: Chain Question
02 Jul 2009 07:18
#303845
As for removing a link of chain, its not a problem if you can get the chain together again. But definitely check out a new chain and sprockets if they are worn.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Chain Question
02 Jul 2009 07:39
#303850
piece of cake,restore it back to a regular boring bike! :laugh: just kidding
