GS1100 Swingarm installation
  • Kojack1982
  • Kojack1982's Avatar Topic Author
30 Jun 2009 09:17 - 30 Jun 2009 09:31
#303355
Ok i've posted a number of questions on this subject but I want this to go as easy as posible with as little thought (of my own) as possible. Im looking to install a larger rear tire and have heard of people using the katana rim.
My question is if anyone has installed the swingarm with a larger wheel what exactly was your setup
-Chain length?
-offset?
-rim make and width
-any other adjustments of parts I would need to make it work
Thanks for all your help and sorry for being a noob.
Last edit: 30 Jun 2009 09:31 by Kojack1982.
  • happyhubby
  • happyhubby's Avatar
Re: GS1100 Swingarm installation
30 Jun 2009 11:06
#303377
i would also love to do this. please let me know if anyone can figure this out!!! itd help with the swaying when theyre repaving all these roads.
1980 kz550 daily driver
  • Kojack1982
30 Jun 2009 21:39
#303536
nobody?
  • donthekawguy
  • donthekawguy's Avatar
30 Jun 2009 23:11
#303550
I am using a 5.5 Akront rim on a suzuki hub. I had to have a spacer made. I am using a 530 chain and sprockets. The rear sprocket is pretty big-43 teeth which is about 38 in the 630. I tried to use a 110 link chain but it was short. I'm ordering a 120 link soon. I think I lucked out and won't need an offset sprocket. I'm using a 140 width tire.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • Z1109R Fin
  • Z1109R Fin's Avatar
30 Jun 2009 23:57
#303552
Howdy. Z1000R ´83
- ´98 GSXR1100 USD front
- ´99 ZRX1100 rear swing.
- Brakes: front ´Tokico 6-piston calibers off the above GSXR
Rear: Opposed piston caliber off ZRX
- Rims: front GSXR, rear ZRX
- Rear shocks: Öhlins piggy-bags
My advise is try to find a whole rear section, swing+rim+brakes cause then you´ll "only" have to worry about swing pivot point widht and chain-line. Still it´s not a one-niter, takes h#ll of a lot time to make it right.
Here´s mine story bout latest swap I made:
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=254238
Z1000R ´83...Slightly modified...
