fork swap
- sbjones
fork swap
11 Mar 2006 23:03
started doing my fork swap today. nocked it up. and let me tell you i love it.
now alls i have to figure out is the bearings. does any one know what bearings are needed (by number) to mount a usd gsxr fork (2001) to my '78 kz 650
really need some help here, looks like i just need bearings
thanks!!!!!
thanks!!!!!
- sbjones
Re: fork swap
12 Mar 2006 01:40
i went to the pro-flo site for bearing cross references.
some one tell me i am reading this correct, but the kz650-b bearing inside is the same as the 2001 gsxr inner diameter?
if this is correct, i should beable to buy the 650 bearing kit, and fit the bearings onto the gixer steering stem.
correct?:huh:
correct?:huh:
- sbjones
- twowheeledterror
Re: fork swap
12 Mar 2006 13:24
sbjones wrote:
If I'm not mistaken that might be the case.
I have a Gixxer fork setup that I was gonna use and I seem to remember it being VEEEERY close to fitting when I bolted it in.
need some help here, PLEASE!!!!!
- Duck
- e vica na i sau na ga
Re: fork swap
12 Mar 2006 16:25
I glommed a copy of head bearing size with bike models underneath a while back from the SOHC4 forums and posted it
here
It goes through 2001 and should have your GSXR.
-Duck
-Duck
- sbjones
Re: fork swap
12 Mar 2006 23:28
i think i may just go for it. i will measure first. but man i do think it will work.
if any one else has done this swap, please feel free to let me know.
thanks you guys.
thanks you guys.
