cheap rearsets!
  • wiccadogg
  • wiccadogg's Avatar Topic Author
cheap rearsets!
11 Mar 2006 22:00
#30238
heres my idea for cheap rearsets.
i'm sure it's been done before. if not it should have been.
this is what i did.
i threaded the upper posts that originally held stock driver peg brackets. also threaded a set of freestyle/bmx bicycle foot pegs to match.
the new pegs screw on. original acorn nut was reinstalled, inside of foot peg, using a lock washer to keep pegs secure.
Post edited by: wiccadogg, at: 2006/03/12 01:34
  • wiccadogg
Re: cheap rearsets!
11 Mar 2006 22:17
#30239
original shifter had to be bent to get the shape needed.
hole was drilled\threaded for new shifter peg.
i used an old toyota head bolt covered with 3\8 hose and washers.
after shifter peg was installed the excess shifter was cutoff. the inside end of shifter peg bolt was hammered down to prevent bolt from becoming loose.
  • wiccadogg
Re: cheap rearsets!
11 Mar 2006 22:25
#30241
on the brake side, the stock brake peddel was cut to size, drilled, threaded.
i used the same style bolt as the shifter peg and hammered down end to prevent bolt from becoming loose.
  • wiccadogg
Re: cheap rearsets!
11 Mar 2006 22:32
#30243
i covered the hole at end of brake arm with an 1981 dime
cuz it fit so perfect and i couldnt think of anything else:whistle:
fin
  • dutchz
  • dutchz's Avatar
Re: cheap rearsets!
11 Mar 2006 22:53
#30251
Cool man. I like the idea of using bmx pegs. I would consider something similar because they look cool, but I need pegs that flip up because my bike is kickstart only. I just reversed the footpeg mounting brackets left to right and upside down,then mounted some pegs upside down. Works pretty good as well.
1974 Kawasaki Z1
Stock front hub and rear axle.
  • indykaw77
  • indykaw77's Avatar
Re: cheap rearsets!
12 Mar 2006 03:08
#30261
Good thinking! The dime is a nice touch.....
Kawasaki Motorcycles...because cars lean th wrong way!
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: cheap rearsets!
12 Mar 2006 05:50
#30294
Good ideas. I've been going over different ways to do a cheap set of rearsets. My single mounting bolt for the pegs is a little further forward though, but I have some spare sets of pegs that I put on to move them further back. I'd just need to shorten the shifter/brake levers, similar to what you have done.
I like how this KZ700's pegs and shifter set up:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Kawozaki
  • Kawozaki's Avatar
Re: cheap rearsets!
12 Mar 2006 09:24
#30342
I like this idea alot! I may have some fabbing to do while the head/cylinders are out getting 'freshened-up'!
  • twowheeledterror
  • twowheeledterror's Avatar
Re: cheap rearsets!
12 Mar 2006 09:31
#30345
With a drill, a dremel and some plate you could make folding bike pegs. Just an idea.
  • Kawozaki
  • Kawozaki's Avatar
Re: cheap rearsets!
12 Mar 2006 09:53
#30352
I don't thinks he's plannin' on throwin' the old girl through the twisties like it's some kind of super sport, TWT!!!:lol: ;)
  • btchalice
  • btchalice's Avatar
Re: cheap rearsets!
12 Mar 2006 10:08
#30358
wont the shorter levers require more pressure to baake and shift?
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • twowheeledterror
Re: cheap rearsets!
12 Mar 2006 10:09
#30359
Yeah, true.
I am still in the mindset of my crazy cafe. haha
