1982 gpz1100 vin location on frame?
- flhwesty
26 Jun 2009 18:14
Can anyone tell me were to find vin on 1982 gpz1100 on the frame? There is not one on the neck??
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1981 GPz1100 KZ1100-B1
1977 KZ1000LTD
1978 Z1R
- flhwesty
Re: 1982 gpz1100 vin location on frame?
26 Jun 2009 19:16
Someone must know?
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1977 KZ1000LTD
1978 Z1R
26 Jun 2009 19:18
Sometimes the neck located info is lost incident to powder coating.
Good Luck!
Good Luck!
- MFolks
26 Jun 2009 19:20
It should be right below the steering head on the left side.
- flhwesty
26 Jun 2009 19:28
This is all I can find. "made in japan khi"
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1977 KZ1000LTD
1978 Z1R
26 Jun 2009 20:02
Perhaps a damaged frame was replaced with a new replacement frame.
Good Luck!
Good Luck!
26 Jun 2009 20:11
For example, checking with kawasaki.com gives the part number for a replacement frame, which is no longer available from the factory.
But when it was available, I believe it would have arrived without a vin number.
Part Number Add to Picklist (Qty):
Description: FRAME-COMP,US
Package Quantity: 1
Item Status Code: Canceled
Good Luck!
Package Quantity: 1
Good Luck!
- flhwesty
26 Jun 2009 20:47
Yes. after doing a little research on the net, i think it is a Kawasaki replacement frame. but they did not re stamp it!!! i guess i will have to get it stamped??Also is there anyone repoping the stickers??
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1977 KZ1000LTD
1978 Z1R
26 Jun 2009 21:28
The Certificate of Title, tag registration, or other ownership papers, may include the original vin if needed to stamp into the frame.
Good Luck!
Good Luck!
- Mcdroid
- Gone Kwackers
27 Jun 2009 03:46
Each state is different when numbering replacement frames and cases...and each state has a different numbering series. It may be difficult to get your state to reissue a number that has already been issued (the original frame VIN...you are going to need proof that the original frame was destroyed)...do you have the title? In rare circumstances, when the original frame VIN is destroyed, and not reissued, the state will use the motor VIN as the registered VIN (ordinarily it is not recorded). There is a fellow who visits the Z1/Z900 owners group on Multiply.com who claims to be able to repro the head stickers but he may be a bit 'fringe' as I've not been able to see any results.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- flhwesty
27 Jun 2009 03:51
Thanks for the help/replies. i was so excited to get this bike I never looked at the frame numbers until I got home!! i have the ownership papers and should have no problem getting them transfered to me.
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1977 KZ1000LTD
1978 Z1R
