Rear Brake questions - 79' KZ650
- The Garbone
- User is Currently waiting for his bailout check..
26 Jun 2009 14:15
Well, my rear brake is a bit useless at the moment.. It works but not all that well, tons of movement and no were near getting it to lock.
I bled it and replaced the the pads and that only helped the situation marginally so now I am down to 2 things to firm it up.
1.Shims- when I replaced the pads yesterday after removing the cobwebs I discovered there are no shims. Were can I get these or can I make them up myself? I went to the local salvage yard and the only set I could find were rusted to non functional status.
2. Rear Master cylinder rebuild- Were can I obtain a kit for this? I checked Z1 but they do not have one specifically listed for my bike. I have had little luck googling one up as well. Is there an alternative model/year that will fit the bill?
2007 Royal Enfield Iron
1979 KZ650 & Hack
1949 Ford 8n
1979 KZ650 & Hack
1949 Ford 8n
- PLUMMEN
Re: Rear Brake questions - 79' KZ650
26 Jun 2009 15:57
id flush out all the brake fluid and keep bleeding them,see if that helps
