Forks not holding air
- c_aasland
11 Mar 2006 19:19
This is my first experience with forks that won't hold air pressure. I am going to rebuild the forks (replace the fluid, check bushings, new seals, etc) in the process, I'm wondering if there's anything I should look for regarding the air leak?
I figure I'll pay extra attention to the pressure balancer, and maybe even replace the valve core. Where do they typically leak?
- RetroRiceRocketRider
Re: Forks not holding air
11 Mar 2006 20:55
I can't say that there is any particular place in the forks regarding the air system that would leak. The fork oil seals however are the most common (and noticeable) to leak.
You can always replace the O-rings (ref# 92055B in the pic below) and what Kawi calls a "cap" (ref# 92055) on the air valve to rule them out as being the cause of the air leak.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- c_aasland
20 Mar 2006 08:42
I don't see any fluid comming out of the fork seals - can they leak air and not fluid?
- NormZ
20 Mar 2006 11:56
I rebuilt my front forks two months ago in an attempt to keep them from leaking air, but it didn't help much. I considered replacing the air balancer tube but it is pretty expensive so I ended up just replacing the seals and fluid and inspecting and oiling all o-rings. Still leaks
. I fill up to 10 psi and by two days later it's down to almost an immeasurable 2-3 psi.
- c_aasland
20 Mar 2006 12:13
Have you tried replacing the valve core on top of the fork leg?
- c_aasland
21 Mar 2006 05:27
I just had a thought. If I can't get the forks to hold air, and the air is used to increase the preload, can I simply add a spacer to increase the preload? Has anyone tried this or think that I should/should not do this?
- NormZ
21 Mar 2006 08:07
c_aasland wrote:
I have not. Probably would be a quick & easy change to try though.Have you tried replacing the valve core on top of the fork leg?
