DOT 3 vs DOT 4 Brake Fluid
  • Maverick
  • Maverick's Avatar Topic Author
24 Jun 2009 19:49
#301876
I just flushed my brake lines with new DOT 3 fluid only to find out that the master cylinder has a leak. Instead of rebuilding the master cylinder, I bought a 'newer' used MC off of ebay, but it calls for DOT 4 instead of DOT 3! D'oh! Well, I've heard that 3 & 4 are very similar and I'm wondering how thoroughly I need to flush the DOT 3 fluid out of the brake lines? Can I just 'push' the DOT 3 fluid out by adding DOT 4 to the master cylinder and pump until I think I have all of the DOT 3 out of the lines? How would you do it?
Thanks in advance!
1981 KZ1000M1
Re: DOT 3 vs DOT 4 Brake Fluid
24 Jun 2009 21:37 - 24 Jun 2009 21:42
#301896
Maverick wrote:
...Can I just 'push' the DOT 3 fluid out by adding DOT 4 to the master cylinder and pump until I think I have all of the DOT 3 out of the lines? How would you do it?
YES. That method is just fine. Same for the routine "flushes" without requiring re-bleeding from scratch.
I use a rubber squeeze syringe to remove most of the existing reservoir fluid, but leaving the bottom ports covered with fluid so as to avoid air entering the line. Then fill with new fresh fluid, pump it through (always leaving the bottom ports covered with fluid so as to avoid air entering the line) and repeat refilling and pumping until the new fresh fluid exits the bleeder valve.
Good Luck! :)
Last edit: 24 Jun 2009 21:42 by Patton.
  • Becker
  • Becker's Avatar
  • The Doctor Will Rise Again
24 Jun 2009 22:21
#301905
Patton is absolutely correct. You can convert from DOT 3 to DOT 4 without a major overhaul but not the other way around. The major differences is the boiling point. 400 degrees F for the DOT 3 and 500 for the DOT 4 if they are uncontaminated. (If I remember correctly)
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
  • wrangler615
  • wrangler615's Avatar
25 Jun 2009 16:55
#302050
Realistically you can use DOT 3 or 4 in either system. Dot 4 only has a higher boiling point because it is "drier". Brake fluid being hydroscopic inherently wants to absorb water. Dot 3 and 4 will both do this if not sealed tight. You CAN switch back and forth no problem, but if mixed you can only expect the performance of a DOT 3 fluid. The only thing NEVER to do is mix DOT 5 fluid with either 3 or 4 fluid. DOT 5 is a silicon based fluid that WILL NOT mix with the petroleum based DOT 3 and 4.
83 Kaw KZ750F1 - massive money pit
82 Zuki GS1100G - my daily driver, possible sacrilege I know
