brake pad wear
  • dan76kz900
  • dan76kz900's Avatar Topic Author
brake pad wear
11 Mar 2006 13:46
#30150
I was looking at my brake calipers today.. and I was trying to understand how they work. The rotor goes in the caliper between the brake pads. Piston goes inward and clamps the pads together to stop. I was looking at the pads, the amout of brake pad material sitting pass the caliper itself between the rotor is just about 1mm, not even 1.5mm I dont think. So this means the brake pads are worn down too much and need replacing after 1mm. Is this normal ? These brake calipers I bought are supposely have brand new brake pads in them.
  • wireman
  • wireman's Avatar
  • Visitor
Re: brake pad wear
11 Mar 2006 14:36
#30155
yeah that sounds pretty thin .post picture of pads if you can.;) goodluck,happy wrenching!
