Chain Question ???
- ProStreet
Chain Question ???
22 Jun 2009 17:57
I am just finishing up a 77 kz100 ltd restoration went to put the chain on and its about half a lik=nk short ?
can I use two is it safe can't see why it wouldn't be
but thought I'd check
thanks
tom
thanks
tom
- H2RICK
- Is this a fun bike, or what!!!
Re: Chain Question ???
22 Jun 2009 20:42
Aha....cut it one link too short, did we ???
Well, don't feel bad.....cuz we've all done that at least once.
I, personally, would NOT put an extra link in there with 2 master links. A master link is the weakest part of any chain....and now you'd have TWO of them. Bad idea, IMO.
Bite the bullet, buy another new chain and cut it correctly next time.
PS: not knowing your abilities/experience.....but.....you DO have the axle all the way forward in the swingarm slots, don't you ??......just asking.....
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- DoubleDub
22 Jun 2009 20:43
Is it the same chain that came off the bike before the resto? Looks like the '77 Kz1000 should have a 92 link 630 chain from what I can find (same as my 900).
www.z1enterprises.com/detail.aspx?ID=3372
www.z1enterprises.com/detail.aspx?ID=228
If it is a 92 link and it still doesn't fit, something ain't right.
- Vter Bob
23 Jun 2009 14:02
What about going down one or two teeth on the rear sprocket? Sprockets are less expensive than o-ring chains and you'll get better cruising RPM.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
23 Jun 2009 14:53 - 23 Jun 2009 15:03
H2RICK wrote:
If not already done, would loosen nut at rear end of torque link, loosen rear axle nut (very loose), loosen both wheel adjusters and drop them out of position, and kick rear tire (as in football :lol: ) all the way forward.
Easiest done with rear end suspended and tire off ground. Usually works well with bike on centerstand.
Good Luck!
...PS: not knowing your abilities/experience.....but.....you DO have the axle all the way forward in the swingarm slots, don't you ??......just asking.....
Good Luck!
Last edit: 23 Jun 2009 15:03 by Patton.
- ProStreet
23 Jun 2009 16:17
Thanks guys my old eyes evan with my glasses the 3 in 33 turned out to be an 8 when I used the magnafying glass too so it was a 38 tooth 5 over stock, his buddy drag races kz1000 so he has a good stock pair 15 and 33 and all fits fine
Thanks Again
Tom
Thanks Again
Tom
