530 conversion help
  • toad
  • toad's Avatar Topic Author
530 conversion help
21 Jun 2009 08:48
#301070
I have a 4.5" katana rim with a 530 47 tooth sprocket for my 78 kz1000 and was wondering a front sprocket match would be if I wanted to stay around the 15front and 40rear 630.So what would my counter sprocket be to reflect that but in a 530, thanks
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
  • bountyhunter
  • bountyhunter's Avatar
Re: 530 conversion help
21 Jun 2009 15:12
#301127
A ratio of 15F/40R corresponds to 17.6F/47R. Obviously, you would have to round off the front to either 17 or 18.
  • StreetfighterKz
  • StreetfighterKz's Avatar
21 Jun 2009 17:33
#301159
I'm running a 18/40 530 combo with a 4.5" ZX6 rim on my '78 1000. I was running a 18/45 and could pull stumps out of the ground with that gearing. Acceleration was awesome but I was topping out at about 100mph.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • toad
21 Jun 2009 19:32
#301187
thanks and what size of tire did you put on that rim? I was also wondering if I could use my kz axel or I have to find the axel for the katana rim or the gs1100 axel
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
  • StreetfighterKz
21 Jun 2009 19:47
#301193
I have a 160/60-17 Conti-Force on it now. You could run a 170 BUT you're only gaining 5mm per side and you get a flatter profile with the narrower tire.
What arm are you using? The normal thing to do is use the axle made for the arm as the chain adjusters/plates are made for the axle and arm. Then you adapt the wheel to the axle.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • Royal1MC
  • Royal1MC's Avatar
  • Is it just me, or is it just great to be on a KZ
21 Jun 2009 20:31
#301204
I currently run 17/38 which works good for me. 17"x 5 rear off a zx6. My first set up was 17/43, which was good out of the hole, but fell flat on the bottom end.
Try this link, helps out on figuring gearing:
Good luck
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
  • toad
22 Jun 2009 05:21
#301265
I am using the gs1100e swingarm, so I take it that I need the axel for it and then us the correct bearings to make it work.Also I wanted to try and use the rear sprocket since it came with the rim, thanks for all the help,great sight.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
