Rear Brake Lever Removal
- letthegoodtimesroll
11 Mar 2006 08:02
Is there any easy way to remove the rear brake pedal (disc brake)? I've used liquid wrench, WD-40 and heat. Any help here would be appreciated.:blink:
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
- wireman
Re: Rear Brake Lever Removal
11 Mar 2006 09:21
did you remove the spring yet?carefull those springs can suprise ya,take it from a guy with a permanent broken outer ear thanks to a brake pedal!:whistle:
- indykaw77
11 Mar 2006 11:11
AMEN to that! When I took the one off mine (to facilitate the rearsets), had to pry the spring into position to come off. After that, the pedal itself needed very little convincing. But watch that spring!!!!!
Kawasaki Motorcycles...because cars lean th wrong way!
