Kz900 Rear Sprocket >35T
- DoubleDub
18 Jun 2009 16:15
Does anyone make a rear sprocket for the stock 76 Kz900 wheel that is larger than 35 teeth?
- MFolks
Re: Kz900 Rear Sprocket >35T
18 Jun 2009 17:11
Have you tried these websites?
1. www.rebelgears.com
2. www.sprocketspecialists.com
3. www.sunstar-mc.com
4. www.kosman.net
5. www.pmfronline.com
6. www.redlinecycle.com
7. www.reproductiondecals.com
8. www.scnitzracing.com
9. www.kzzone.com
10. www.aperaceparts.com
11. www.dynoman.net
4. www.kosman.net
9. www.kzzone.com
11. www.dynoman.net
18 Jun 2009 19:45 - 18 Jun 2009 19:46
DoubleDub wrote:
If not already considered, a feasible alternative might be to fit a smaller countershaft sprocket (instead of a larger rear sprocket).
Click here > for 14 tooth css from Z1E
Good Luck!
Good Luck!
Last edit: 18 Jun 2009 19:46 by Patton.
- DoubleDub
19 Jun 2009 05:51
Thanks Patton! Didn't think of that. Do I need to change chain sizes going to 14/35 from 15/35?
- racer54
19 Jun 2009 17:41
Z1Enterprises sells sprockets in many different sizes. Although going down to a 14T front sprocket is an option, it would be better to go bigger on the rear. Smaller front sprocket wears out the chain faster. Sprocket Specialsts have them from 30T-52T for $69.95-$99.99.
19 Jun 2009 17:45
Existing 630 chain should be just fine.
This will improve acceleration from stop or crawl speed, and is great fun for playing around, but make for a very busy cruising rpm.
Good Luck!
Good Luck!
- bountyhunter
19 Jun 2009 17:45 - 19 Jun 2009 17:46
DoubleDub wrote:
Shop around, I saw tons of "stock type" rear sprockets made of steel that have MORE teeth than stock amount. It's when you want to go to a smaller than stock rear that you have to grab your ankles and pay +$70 for a special cut aluminum sprocket.Does anyone make a rear sprocket for the stock 76 Kz900 wheel that is larger than 35 teeth?
Last edit: 19 Jun 2009 17:46 by bountyhunter.
