Another swingarm conversion question
  • Peterbilt
  • Peterbilt's Avatar Topic Author
18 Jun 2009 09:48
#300256
I read here that the general consensus on a direct bolt on is the 81/82 GS 1100. Will other model year GS swing arms fit as well? I love the look of the 99 ZRX tubular swing arm but for simplicity sake and monetary cost of fabing the ZRX conversion, I would like to go with the GS box style direct bolt on.
Will a 88 GSXF Kantana 1100 swing arm also bolt on?
Almost forgot this will be installed on a 76 KZ 900 A4. I will also be keeping my stock wire wheel with drum brake. Later I would like to respoke the drum to a wider rim and use a wider tire. Try to keep as much of the stock look as possible. Any thoughts on that 88 GSXF?
76 KZ 900 A4 Andrews 2x cams V@H exhaust 28mm Mikuni carbs off a KZ1000 rejected with accelerator pump removed and pod filters
