New Frame?
- NOS
New Frame?
10 Mar 2006 19:39
I was thinking of getting another frame for my 1982 KZ550 LTD because mine was modified (not very well, I might add.) by the prior owner.
I know of someone that has a 1983 KZ550 (LTD??) frame for sale with the title. I want to know if my swingarm, engine and everything else will bolt up without mods since the '83 was a shaft drive and my '82 is a chain drive?
Any help you can give me would be great.
Thanx everyone
Thanx everyone
- NOS
Re: New Frame?
12 Mar 2006 21:06
Anyone,...anyone?
If anyone knows, or even has an idea about this let me know.
Thanx again:)
Thanx again:)
- RetroRiceRocketRider
Re: New Frame?
12 Mar 2006 21:37
I'm fairly certain you're going to need to use both the front bevel gears AND swingarm from the donor bike to be able to mount your engine into that frame. And then you're still going to need to modify the engine cases to accept the bevel gears.
The swingarm on the shafties also houses the driveshaft itself and is large in diameter and width, therefore the pivot point where the swingarm mounts into the frame is also wider.
At least it's that way between my ZN700 and a KZ700 which share almost identical engines.
Post edited by: RetroRiceRocketRider, at: 2006/03/13 00:39
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- Duck
- e vica na i sau na ga
Re: New Frame?
13 Mar 2006 04:52
I doubt it will work. The chain drive bikes have a through bolt and sleeve to mount the swing arm. The shaft drive bikes, generally and according to kawasaki parts diagrams, have a pivot on either side of the swing arm and pass the driveshaft through the pivot axis.
parts diagrams
buykawasaki.com/
select 'order service manuals'
follow the green brick road
If you're up to some welding and want to update, the late 80's gpx600 have a tube frame. I've seen a number of them with blown engines, often cracked water jacket in cylinder head, for sale cheap. They have a nice toaster tank and IMO look good with the plastics removed.
-Duck
parts diagrams
buykawasaki.com/
-Duck
- NOS
Re: New Frame?
13 Mar 2006 10:45
Thanks guys, I just wanted to make sure before I got caught up in a lot of fab work. I think I'm gonna wait a few weeks before I start looking for a new frame, because the KZ750 needs alot to get her road worthy and I can just keep riding the KZ550 as is for now.
Once again thanks for the post and info.
Ride safe
Post edited by: NOS, at: 2006/03/13 13:47
Ride safe
