Front wheel shimmy
- kzb4
Front wheel shimmy
16 Jun 2009 19:33
Hello, I have a 1980 kz 1000, I have a shimmy, side to side movement of the handle bars/front end at approx. 35mph or less when my hands are taken off the handle bars. I'm thinking wheel balance, but I think that would be up and down movement of the wheel. Any input or advice would be appreciated. Thanks, Tom.
1980 KZ 1000 B4
- Kawickrice
Re: Front wheel shimmy
16 Jun 2009 19:38
I would check the steering stem bearings. Then put tapered roller bearings in. Also check front and rear wheel bearings and the swingarm bearings.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- WABBMW
- Let The Good Times Roll !
16 Jun 2009 20:00
I had this problem, so I made sure the tires were well balanced. This helped a little, but did not cure the problem. I found that the front tire was out of round by less than 1/16". The rear by about 1/8". The wheels ran very true.
Then I bought a second set of wheels and some new tires. The new tires were perfectly round, and I got them balanced to within a few grams. PROBLEM SOLVED. No more shimmy and velvety smooth.
The old tires still have some wear left in them, so I put the front one back on, just to putter around town with, and to save my new tires. Amazingly the front remained fairly well behaved. Then I also put the old rear tire back on, and the shimmey came back! So the rear tire was causing the shimmy. Weird, but go figure.
Anyway, check for balance. Check for out of round. Also, I am convinced that my old tires were not very uniformly made - hard spots here and there. Food for thought.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
- gane
16 Jun 2009 21:02
All good posts, however, most common "shimmy" on de-cell is caused by un-even wear at ft tire. additional notes. loose or burnelled stem bearings are exibiteted by a feel at bars..ie notchy steering,"hunting for center"...2, wallowing when tipped over in long constant radius turns,under load, worn swing arm bushings/bearings. Stem bearings are prevelant prob. and once damaged are more cheaply remidied w/tapered timpkin bearings. I'll not say they're better, simply cheeper and easier to adjust and live longer. end results are cumulitive. just replacing a cupped front tire may end goofy handling, for now, worn/goop loaded bearings will return. it's really not that big a chore, hav a look G
[img][/img] 1977 KZ1000A1
- kzb4
17 Jun 2009 10:16
Thanks for your help, I will check my wheel runout and balance. I'm not quite sure how to check the steering head bearings for wear, but i will check into that. Thanks, Tom
1980 KZ 1000 B4
- Calhoun
- Hayabusa= I ride to the strip club in flip flops
17 Jun 2009 12:58
I had a problem with my tire. I had new Kendas on it when I got it and switched to Dunlop GT501s. I wouldn't put Kendas on my garbage can.
80 IT175, 84 XL200, XT250, 95 ST1100 96 xr650l (30k miles),kz1000, KX250 97'
Last and most important 93 KX500.
- Oldwolf
17 Jun 2009 13:57
I had a 1975Z1B that developed a shimmy and shake in the front end. I found my Brake Calipher bolts were loose.
1977 KZ1000A1, 1105cc,Mikuni RS34mm FS, K&N Pods,Kerker 4/1,Dyna S Ign,Coils & Plug Wires,Progressive Sup. Front&Rear, Derale Oil Cooler.
- WABBMW
17 Jun 2009 19:28
Calhoun:
Funniest thing - My old tires were Kendas. Are we seeing a pattern here? They got reasonable traction, and ran for high miles, but they just aren't manufactured to much precision,in my opinion. Handle bars shake; cornering is uncertain because it is not smooth; the shocks are being worked constantly, even when the tires are balanced; the tires were out of round; etc. etc.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
