78 motor fit 77 frame??
- Kojack1982
16 Jun 2009 17:41
I have a 1978 KZ1000 B LTD that i didnt have a title for and picked up an 77 kz1000 frame with a vin of KZT00 A I wanted to get the new frame powder coated and swap the everything over to the 77 just not sure if it all will fit. If anyone can enlighten me
Also I picked up a 82 gs1100 swingarm and want to keep the stock kz tire for now but im assuming im going to need a new chain any ideas on length??
- Mark Wing
Re: 78 motor fit 77 frame??
16 Jun 2009 17:46
I'm not a 1000 guy but I think the mounts for the body work is different?
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- PLUMMEN
16 Jun 2009 18:55
the 78 stuff will bolt on the 77
- trianglelaguna
16 Jun 2009 19:17
easy switch..1 hr if you take breaks....good luck...pictures???
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- otakar
16 Jun 2009 19:18
Same motor same frame.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- austin3119
16 Jun 2009 20:04
New chain and offset sprocket. I think 5/8's if you want to run a 160. Don't know on the length though.
- donthekawguy
16 Jun 2009 23:46
Are you using a 630 chain or 530? Do you have a chain breaker? If you do go with a 120 link. The gs arm is about an inch and a half longer. I went with a 530 chain and sprockets and a 110 link wasn't even close.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
